February 08, 2026, 05:32:35 PM *
Author Topic: STUMPED WITH BRAKE SPRING!  (Read 768 times)
Builder630
Chicago
« on: May 17, 2014, 10:01:11 PM »
I simply CAN NOT figure out how the brake spring clips on to the caliper. Can someone PLEEEEAAASE show me the way?
olddog1946
Moses Lake, Wa
« Reply #1 on: May 17, 2014, 10:26:20 PM »
There should be two tabs that position the clip onto the caliper, they don't really grip as much as potion it so spring tension is applied to the pin.
If you can't figure it out, you've probably got one of the tabs broken off. I did when I took mine apart to rebuild them. Had to order new ones.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
pancho
Bonanza Arkansas
« Reply #2 on: May 18, 2014, 04:17:01 AM »
Front clip or rear??  Take a look at one of the other calipers on the bike to see how they go in there, I have scratched my head over the same problem.
Bone
« Reply #3 on: May 18, 2014, 07:17:09 AM »
#6 ?
« Reply #4 on: May 18, 2014, 07:32:37 AM »
A camera shot BEFORE DURING and AFTER disassembly really helps. IF you have not broken a tab it really ONLY goes together one way. I KNOW I KNOW-really not much help am I??  2funny RIDE SAFE.
