Trying to find 7/8" to 1" handlebar adapters.
Started by John Schmidt, Sun 18, May 2014, 21:25:07
Previous topic - Next topic
I can find 1 1/8" adapters but that's a larger diameter than Valk handlebars. I used to see them all the time, now seem scarce as hen's teeth. Any suggestions where to look, haven't found any on Ebay, JP Cycles, etc.....looked at most of the suppliers I can think of.
tank_post142
I got a rock :(
VRCCDS0246
tank_post142
#2
like this ?
http://www.jensonusa.com/!Y!7QGdEOvTDY8kcobW7enA!/Problem-Solvers-Handlebar-Clamp-Shims-1?utm_source=FRGL&utm_medium=organic&gclid=CKDYm7SBt74CFQEdOgodPGYAgA
http://www.lowbrowcustoms.com/p300/buy/m-c-parts/bars-risers-amp-controls/risers/british-standard-handlebar-shims-reducers-run-7-8-inch-handlebars-with-1-inch-risers-or-p-clamps-/
also do a search in motorcycle parts/ebay for handlebar shims.
I got a rock :(
VRCCDS0246
I'm not sure I understand what you are looking for, but have you looked here?
http://www.flandersco.com/Products.html
I already have the 7/8" riser as used on the GL1200, I have a Valk handlebar I want to use. Actually, they're not risers but an integral part of the top tree. I used to be able to find adapters that bolted into the 7/8" pocket, then the adapter was cut for 1" bars.
The look like this, only for 1" not 1 1/8".
http://www.ebay.com/itm/New-7-8-To-1-1-8-Handle-Bar-Adapter-Riser-Fat-Bar-Conversion-/360807017658?pt=Motors_ATV_Parts_Accessories&hash=item5401c62cba&vxp=mtr#ht_4253wt_1105
tank_post142
I got a rock :(
VRCCDS0246
jdp
check out the dirt bike shops the motocross racers are going to 1 inch bars and they have the adaptors
tank_post142
John: what i found is a set of 1" valkyrie riser blocks. you could reshape the nub that fits into the original riser or just cut it off.
I got a rock :(
VRCCDS0246
