February 08, 2026, 05:32:54 PM
Truck Stack Info. Please
Topic: Truck Stack Info. Please (Read 1083 times)
scoobydoo
Evansville, Indiana
May 21, 2014, 04:37:06 PM »
Hey just want to make sure I'm on the right track before I hack up my new stacks.
I need to cut to my desired lenght, then cut a slot down the side to allow the stacks to pass the bracket that holds the muffler.
Is that the best way & what do you use to cut so it doesn't blue the stack?
Scoobydoo
Re: Truck Stack Info. Please
May 21, 2014, 04:45:20 PM »
Hey phil, I put blue painters tape on mine and used a square to draw my lines. I then used a jig saw to cut the section out. Peel the tape off and your done. I also tig welded my stacks to the cans because they were a little loose. Put about 8 tack welds on each stack. So if I ever have to replace them it's going to take a ittle work with a cold chisel and hammer to break them free.
BigBad1
1999 Interstate
Garner NC
May 21, 2014, 04:49:01 PM »
Same here. I used blue painter tape to mark them and used a Jig saw with a blade for metal. I did not have to do anything to hold them on. They were very very tight and I could not get them off when I sold the bike.
May 21, 2014, 05:02:53 PM »
I think the reason mine were so loose is because I pretty much cut the cans off at the mounting bracket. Thinking it would give it a little more noise, and I think it did. So all that was holding it on was and inch or 2 of solid truck stack then the split stack from the bracket to the front.
Mr.BubblesVRCCDS0008
May 22, 2014, 03:22:51 AM »
I used masking tape and a new fine tooth blade in my hacksaw and went slow and easy. Took very little time or effort.
Kunkies
Charlotte, NC
May 22, 2014, 04:05:49 AM »
http://www.timskelton.com/valkyrie/how_to/stacks.htm
Reply #6 on:
May 22, 2014, 12:45:13 PM »
I used taped and my saws all. Yr later i ran a self tapping screw from the back side cause the stacks would work loose.
