February 08, 2026, 05:32:58 PM *
Author Topic: Engine ticking using mp3 player  (Read 753 times)
Hog Killer DS0048
Tucson, AZ
« on: May 22, 2014, 07:43:58 AM »
I know I've read a fix for this on the board and I've done a search and can't find it. When I use my mp3 player, I get engine ticking through the speakers. Any help would be appreciated.
Bone
« Reply #1 on: May 22, 2014, 08:14:19 AM »
On my 98 Tourer I had a similar problem. I'm playing an MP3 through the Honda CB control mounted on the left handlebar.
Flicking the thumb lever I get CH (channel), Vol (volumn) and Com (comunicate ?) not sure.
After giving up I was playing with the thumb lever and Com was showing 5. As I reduced that number it went to 1 or 0 and then Off.
Suprise the noise cleared and nothing but music. 5 must be a factory setting every time I restart I have to go to Com and reduce it to Off and all is well again.
The CB unit is a Clarion.
Hog Killer DS0048
Tucson, AZ
« Reply #2 on: May 22, 2014, 08:35:56 AM »
I have the factory unit on my Interstate and  and as far as I can see, it doesn't have a Com option.
tank_post142
south florida
« Reply #3 on: May 22, 2014, 11:24:30 AM »
replace the bad sparkplug wire
I got a rock Sad
VRCCDS0246
Novavalker
99 Interstate/2017 Goldwing
« Reply #4 on: May 22, 2014, 03:52:01 PM »
Try one of these.
http://www.crutchfield.com/p_127SNI135/PAC-SNI-1-3-5-Noise-Filter.html
I use one on my interstate for audio on the GPS.
« Reply #5 on: May 22, 2014, 05:39:48 PM »
Do a search for noise filter.
http://www.valkyrieforum.com/bbs/index.php/topic,67434.0.html
I found this latest one from earlier this month. Don't remember if anyone ever did post that they fixed it.
« Reply #6 on: May 22, 2014, 05:44:04 PM »
If it's wired up the left side of the bike ( clutch side ) move the wire to the right side ( front brake ) . Mine did the same after moving the wire ( FIXED ) .It's getting the tic from the coil .
Troystg
DC
« Reply #7 on: May 22, 2014, 06:11:11 PM »
Tick or whine?  Tick would be sparkplug as mentioned earlier and re-routing the cable should help.
Whine is ground or alternator..
Try re-routing first as it is the easiest.
Troy
Troy
Hog Killer DS0048
Tucson, AZ
« Reply #8 on: May 22, 2014, 06:13:26 PM »
Thanks I'll try moving the cable, quick fix, as it is running underneath the left side of the tank. If not, I'll try a noise filter.
Thanks for the replies.
