February 08, 2026, 09:06:26 PM *
Author Topic: bike starving for fuel 99 valkyrie  (Read 885 times)
Kevin p
Ontario canada
« on: May 22, 2014, 08:27:34 PM »
Any ideas my bike works great around town  on drives runs out of fuel figured out today when i open gas cap it start right up good for another 10 min.Going to take tank off tomorrow is there something that controls how air gets in tank.  Bike ran good before stored. Any ideas would be great  thanks
« Last Edit: May 22, 2014, 08:32:05 PM by Kevin p » Logged
ptgb
Youngstown, OH
« Reply #1 on: May 22, 2014, 08:32:38 PM »
Sounds like a kinked or blocked vent line.
 Run it and after it starts to die or dies, use your second key to open the gas cap. If you hear a "whoosh", the vent is not working correctly.
The vent line is the small rubber line behind (towards the seat) the petcock.
« Last Edit: May 22, 2014, 08:34:10 PM by ptgb » Logged
Kevin p
Ontario canada
« Reply #2 on: May 22, 2014, 08:40:14 PM »
Not hearing any noise bike works great around town never know anything was wrong.Been doing a lot of reading. I thought gas was gravity fed.
ptgb
Youngstown, OH
« Reply #3 on: May 22, 2014, 09:10:11 PM »
It is gravity fed. What happens is if air is not getting into the tank to displace the fluid that is leaving it, it will create a vacuum effect, keeping the fluid (fuel) in the tank.
I'll bet you $2.50 that the line is partially kinked. That is why it runs good around town and starves for fuel at higher speeds.
Before you take the tank off, get a zip tie and place it on the edge of the fuel filler. Close the cap on top of the zip tie too allow a small gap for air to get in. Bet it will run fine in all riding scenarios.
8Track
Adelaide, South Australia
« Reply #4 on: May 23, 2014, 12:30:21 AM »
Yes - almost certainly a kinked vent line. You are getting a vaccuum built up inside the tank which is stronger than the force of gravity. By opening the cap you are releasing the vaccuum. Bike will run fine until it builds up again.
Another thing to check is the vaccuum line running from the petcock to the #6 intake runner. If this is cracked then there won't be enough vaccuum to reliably hold the diaphragm inside the petcock open. This issue tends to show up as fuel starvation at higher rpms.
Cheers,
Mark
Kevin p
Ontario canada
« Reply #5 on: May 23, 2014, 07:33:34 AM »
Fogged the carburetors in the fall must have kinked the vent putting tank back on.Caused me allot of grief broke down trailered it home had no spark.Ran the battery low when i was trying to get it off the road,got reading in the form someone posted need allot of juice for spark was after cleaning all the wires couldn't figure it out.Charged the battery got spark,that's when i figured gas problem,Checked carburetors had fuel was stumped.Opened gas cap to pull some fuel out to put in plug hole bike fired up,air locked,Was worried something in the petcock was causing the problem.Easy fix going to be a nice weekend here for a ride.Thanks for the replies,help.Not hard to act stupid sometimes.Cheers   cooldude
« Reply #6 on: May 23, 2014, 08:15:22 AM »
Not stupid.  We have all done things like this.  It is the knowledge on this board that helps us through the problems.
Glad you got it figgered out.
Hay  Cool
Michvalk
Remus, Mi
« Reply #7 on: May 23, 2014, 09:02:23 AM »
Might look in the end of the vent tube for a mud dauber nest cooldude
