February 08, 2026, 09:05:53 PM *
Author Topic: idle question  (Read 1407 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« on: May 24, 2014, 07:35:12 PM »
Question: Why won't my Valk start up without the choke on and stay running?
I have rebuilt the carbs, and sync'd.  Did a desmog also rebuilt the petcock.
I have put about 3000 miles on since doing all the work.  It will start without the choke but will not stay running even when it's 90 degrees outside when I get off work.
Is there something that I can do to remedy this situation?
Thanks in advance for your input and suggestions,
Wewaman cooldude
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
« Reply #1 on: May 24, 2014, 08:25:27 PM »
idle mixture screws not opened to what the engine wants, or idle speed screw not adjusted correctly.
« Reply #2 on: May 24, 2014, 08:34:53 PM »
Do you mean it won't idle at all or just when you first start it up? Mine has to warm up slightly before it will idle without throttle or choke.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #3 on: May 24, 2014, 08:52:12 PM »
It will idle after it warms up.
« Reply #4 on: May 24, 2014, 09:06:35 PM »
I think that's normal. You can give it partial choke to keep the idle up if you want. I usually just give it a little throttle if it's not cold out. It's very seldom cold here 2funny
« Reply #5 on: May 25, 2014, 09:29:35 AM »
Ambient temperature has very little influence
when referencing the engine temperatures.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #6 on: May 25, 2014, 10:06:16 AM »
OK thanks for the lesson   cooldude  I will just use the choke at every initial start up.
Next question...     When I apply FULL choke (lever ALL the way down)  it cranks fine, revs up to about 2000 rpms   then when I turn choke off,  the left side does not release and I have to apply slight pressure to the enrichment slide with my finger to get it to release.  The right side works like it's supposed to.  I have tried adjusting the cable in both directions but it stays the same.   It only happens if I push the lever all the way down, as long as it doesn't get pushed to the bottom of the allowed travel it will release fine.
Wewaman
« Reply #7 on: May 25, 2014, 10:11:57 AM »
Spray all the connections and linkages with a silicone spray and lubricate the cable with a little oil.
This is something that is a good maintenance procedure and need to be done.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #8 on: May 25, 2014, 10:31:27 AM »
 cooldude will do  cooldude
Thanks Ricky-D  cooldude
Wewa
BlueValk
Albuquerque, NM
« Reply #9 on: May 25, 2014, 03:34:27 PM »
Wewaman cooldude
You absolutely should be able to start your bike and have it idle without the choke in 90 degree temps.  And "yes", ambient temps have a whole lot to do with happy idling.
Maybe your ECT sensor is disconnected or not working correctly.  It will add some timing advance and increase your idle "automatically" while the bike warms up.
The connector for the ECT is behind the right neck cover.  Try putting an ohm meter on it and compare it to the manuals numbers.  With it still connected, you should read about 2k ohms.  Too high or too low of a reading will make the ICM ignore it, and your idle will be too low when "cold".
Don't give up, there is something wrong here ...
PhredValk
Edmonton, Alberta, Canada
« Reply #10 on: May 25, 2014, 05:09:12 PM »
Wewa, what RPM does she idle at when warm? My girl idles at just under 1000, but at first start only idles at 4-500 and usually sounds like she's gonna quit. If your warm idle is 7-800 she may need some choke on first start.
Fred.
VRCCDS0237
« Reply #11 on: May 25, 2014, 05:47:14 PM »
Wewaman cooldude
Nah I don't believe it! I bought my 97 new and it has to be choked when it hasn't been running for say 8-10 hours and has been that way since day 1 it only had 10 miles on it when I bought it. It will start without the choke but it will die unless you give it throttle.
« Reply #12 on: May 25, 2014, 06:33:48 PM »
Wewaman cooldude
+1, both my standard and I/S are both like that cooldude
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #13 on: May 26, 2014, 07:14:51 AM »
Fred.
PhredValk  Mine is just like you said , Just under 1000 when she warms up but around 4-500 at first start.  I just give her partial choke like meathead says and all is fine.  cooldude
 BlueValk I will check what you suggested because I did have to remove that cover when I removed the carbs, just to make sure it's still connected.  Thanks,   Wink
  The only reason I'm asking is because there are 2 guys at work who don't need to choke their bikes after we get off of work.
1 is a 1967 Triumph and  1 is a 2011  Yamaha R1
Thanks for all your  knowledge,
Wewaman
« Last Edit: May 28, 2014, 08:42:14 AM by Wewaman » Logged
« Reply #14 on: May 26, 2014, 11:12:52 AM »
Both my Interstates are the same; always need choke on cold starts in any temp (unless I stand there and feed a bit of throttle... which can easily stall the bike so I use choke), though it requires less warm up on choke in warm weather than cold.
Perfect tune, desmog, plugs, valves, new and tight o-rings, carb synch made no difference... well, the bike ran better, but I still need to choke for best cold start.  Cold idle with no choke 900rpm, once warm 1000rpm.
« Last Edit: May 27, 2014, 08:18:46 PM by Jess from VA » Logged
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #15 on: May 26, 2014, 02:30:31 PM »
Thanks Jess I will try to increase my warm idle to 1000 and see what that does.
nogrey
Nampa, Idaho
« Reply #16 on: May 27, 2014, 03:21:49 PM »
Fred.
 CA I will check what you suggested because I did have to remove that cover when I removed the carbs, just to make sure it's still connected.  Thanks,   Wink
Wewaman
I'll do my best to keep this short. On my '01 interstate, it always required a little "fuel enrichment" to get started. Once warm, everything was fine. Still, the fact that my brothers identical Interstate would start right up on the same warm day without the enrichment bothered me. Finally, I purchased a carb balance kit and balanced my carbs. Now mine starts exactly like my brothers does. Never needs enrichment on a warm day. Even after sitting all week.
Now on to my '97 tourer. It also has the "enrichment needed" issue. I know that it can be better because it has been better in the past. This is not a sync issue because I've done that. There are many issues that avail themselves in a similar fashion. Poor starting can be many things. I'm running through them now. Like others, the carbs have been completely gone through. I personally believe my issue is  going to be a bad "o"ring, or improper pilot setting, or a bad slow jet(s), not sure at this point. Only thing I am sure of is that these machines, when properly tuned, will start on a warm day with no enrichment, and idle fine. I've had more than 20 Valkyries in my garage that "prove" that (to me).
nogrey
Nampa, Idaho
« Reply #17 on: May 27, 2014, 03:24:10 PM »
That should not be necessary.
« Reply #18 on: May 27, 2014, 05:17:35 PM »
FWIW, I believe proper idle is 900, but I have a Kury LED meter on my bike, and when idling at 900 at start it often is in the red (working off battery), once idle is at 1K, it's always in the green. I really doubt a 100 rpm idle increase is any big deal, but my electrical system likes it better.
« Reply #19 on: May 27, 2014, 06:50:54 PM »
same here cooldude
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #20 on: May 28, 2014, 09:01:32 AM »
Well I have been to busy riding and working to worry about or even adjust my Idle,  Grin
But it used to start without using the choke (enrichment)  So I was just looking into what I might need to do to get it back to that.
nogrey I'm with you in that I think there is something still out of kilter somewhere.  I have tried using a couple cans of Chemtool B-12 which has made some slight improvements, but not in the starting without idle department.
Then again I might just have to join the Jess and Bighead club  2funny
Thanks again,
 Wewa
