November 26, 2025, 01:28:16 AM *
Author Topic: LED Waterproof rotary dimmer switch with high beam by-pass  (Read 2169 times)
Pappy!
Central Florida - Eustis
« on: May 25, 2014, 03:24:46 PM »
This is a good addition for those thinking about purchasing high powered LED lighting for the front of your Valk.
Rather than having to aim your high powered LED's down and away to keep from blinding oncoming traffic this allows you to select the beam location that is optimum for you. Set the intensity at whatever level you like including OFF and you have the option of full power by simply hitting your high beam switch.
I got the switch from ADVmonster. Not affiliated in the least! Just a cool product that works for our needs.
https://www.youtube.com/watch?v=I490QXP23bY&feature=youtu.be
And a link to the controller.
http://stores.advmonster.com/rotary-led-dimmer-with-high-beam-bypass/
« Last Edit: May 25, 2014, 06:07:36 PM by Pappy! » Logged
