February 08, 2026, 07:30:28 PM *
Author Topic: Tach quit.........now starter non-responsive*******FIXED*******  (Read 2029 times)
CoachDoc
San Diego, CA
« on: May 25, 2014, 08:05:07 PM »
My '97 Standard has been running great. About 6 months ago I had problems with intermittent cutting out of the electricals. Solved that by cleaning the starter connections, replacing the battery (heavy duty Yuasa) and replacing the battery ground cable. Everything was copacetic until today. Bike started normally, ran up the PCH and about a half hour into the ride I noticed the tach was not working. The bike was running fine, all idiot lights,  headlight, tail and brake lights working. When I got home and turned off the ignition, the starter button was totally dead when I tried to start it up again. Absolutely nothing when the sarter is pushed, i.e. no solenoid click, no dimming of the headlight, etc. I tried playing with the kill switch, tried again to start.....still nothing. I put my voltmeter on the battery and it showed 12.60 volts at the battery terminals. Obviously I can't check the alternator output.
I'm assuming there is a connection between the tach cutting out and the no start situation, but a search of threads on this site show nothing quite like what I'm experiencing. Guys have described tach failure accompanied by loss of various lights, etc., but all my lights are fine. Could a bad starter switch cause the tach to not operate? The starter relay connections are immaculate. I'd appreciate any feedback from the experts lurking on the board. Thanks.
« Last Edit: May 28, 2014, 07:59:11 PM by CoachDoc » Logged
CoachDoc
'97 Valkyrie Standard
'05 Goldwing
'74 CB550K
« Reply #1 on: May 25, 2014, 08:46:46 PM »
Sounds to me like the start button may not be releasing properly.
Does it have movement, both in and out?
PhredValk
Edmonton, Alberta, Canada
« Reply #2 on: May 25, 2014, 09:13:47 PM »
Do you have lights when you turn the key? Make sure the battery is OK. On my IS all of the dash electronics started to flash and then quit just before she died due to a bad alternator...
Fred.
VRCCDS0237
CoachDoc
San Diego, CA
« Reply #3 on: May 25, 2014, 09:40:42 PM »
Starter button does have normal movement, but no response. Just realized my headlight is not working. As of right now all the other operating and idiot light remain functional. Battery voltage up to 12.90 after a few hours on the Battery Tender, and no improvement. Battery is only 6 months old.
CoachDoc
'05 Goldwing
'74 CB550K
« Reply #4 on: May 25, 2014, 11:02:01 PM »
I suggested the starter switch because I remember something being said about that and the tach being related.
I would fix that headlight/starter switch first, and when that is OK, see if the tach is still not working, and move one from there.
CoachDoc
San Diego, CA
« Reply #5 on: May 26, 2014, 12:30:35 AM »
Yeah, Im thinking replacing the starter and kill switches sounds like the right place to start. The headlight is of course hard wired.
CoachDoc
'05 Goldwing
'74 CB550K
heavyd
« Reply #6 on: May 26, 2014, 03:44:35 AM »
Same symptoms mine had when my alternator died. I was driving when the tach quit, didn't worry much about that but then my radio quit, I got cut off and the horn didn't work, then I started losing power. Luckily I knew there was a gas station coming up so I was trying to limp it there, when I put my signal light on to turn in that used the last of my juice. If I charged the battery though I could drive for 10-15 mins before it started failing again. If I am reading your posts right though you are still down after charging the battery? You mentioned changing the ground strap, has anything worked lose there and lost ground?
« Reply #7 on: May 26, 2014, 05:02:59 AM »
Like heavyd...I was thinking alternator.  How many miles since you checked the brushes and cleaned out the dust?
CoachDoc
San Diego, CA
« Reply #8 on: May 26, 2014, 09:18:53 AM »
I've never opened the alternator, but it doesn't make sense to me that the alternator could be the culprit. I still had plenty of juice in my battery when the tach cut out, and now with the battery fully charged I still have no headlight, no tach, and no start. I'm thinking wiring or switch related. Make sense? If so, where do I look?
CoachDoc
'05 Goldwing
'74 CB550K
« Reply #9 on: May 26, 2014, 09:30:31 AM »
It may be just the switch this time, but the brushes in the alternators dont last forever.....$5 to change them and blow the dust out, check the bearing and go on for another 50K.  Its cheap easy peace of mind.
Also, the start button/switch is a suspect but also the starting solenoid.  If the terminals are melted thats a whole nuther job
« Reply #10 on: May 26, 2014, 10:11:40 AM »
Do the easy things 1st.
1.  Check the starter switch.   I mean open it up and look at the contacts.  Make any adjustments needed.   Put some electrical grease on it and put it back together.
2.  Start now?  NO
3.  Pull the right side cover and look for a big fat black cover on the wiring.
4.  Slide the cover back and take a look at the connection.   If it is melted and the fuse blown you need to put a new one on.
5.  Refer Jeff K generic parts post in Shop Talk for the part needed.
6.  If that is not the problem, then start chasing ALL battery cables.
7.  Take each end off.
8.  Clean it up, sand on the post and connection material.
9.  Wipe your sanding debris off.
10. Reinstall.
11. Repeat 7 thru 10 till all connections are clean.
12. Still no start, get back to us.
13. Cheers.
CoachDoc
San Diego, CA
« Reply #11 on: May 26, 2014, 10:19:34 AM »
2.  Start now?  NO
10. Reinstall.
13. Cheers.
RJ, great list. I actually have a new starter/kill switch on hand that I bought a while ago while chasing another electrical issue, so I'm going to install that for sure. The main fuse is good.......checked it yesterday. All the battery connections and ground look good also. I disconnected them all yesterday, run over them with emery paper and reinstalled them. Any chance the ignition on/ off switch could be the culprit?
CoachDoc
'05 Goldwing
'74 CB550K
Momz
ABATE, AMA, & MRF rep.
« Reply #12 on: May 26, 2014, 12:13:53 PM »
There is a fuseable link at the solenoid.
Easy check, and it comes with a spare on the solenoid.
ALWAYS QUESTION AUTHORITY!
« Reply #13 on: May 26, 2014, 01:47:53 PM »
Momz are you referring to the one I noted in #4?
I have a picture somewhere of it burnt, I'll look & see if i can find it.
Replace with this part #:
CoachDoc
San Diego, CA
« Reply #14 on: May 26, 2014, 02:38:37 PM »
OK, now I'm confused. I thought that in your #4 you were talking about the metal dog bone main fuse.
CoachDoc
'05 Goldwing
'74 CB550K
Highbinder
Bastian/Tazewell,VA.
« Reply #15 on: May 26, 2014, 05:25:38 PM »
Check your diode, that little device determines where all the power goes and when, when it goes everything gets confused, sometimes things work sometime they don't....look in your fuse box, next to the fuses on the right you will see what looks like a fuse going vertical, that's the diode, I usually just replace it to see if its good, there is noway to tell by just looking at it..could be your problem..good luck.
CoachDoc
San Diego, CA
« Reply #16 on: May 28, 2014, 08:05:45 PM »
Replaced the starter/kill switch combination today and I once again have a starter, headlight, and a working tach. Spent a lot of time pouring over the wiring diagram and it is pretty obvious the connection between the starter and headlight. How the tach enters the equation still has me scratching my head.
I truly love this bike. I've been riding for 48 years, had lots of bikes, but this may be my all time favorite. That said I'm hoping for a better ratio of riding time to troubleshooting/fixing time in the next couple of years compared to what I've experienced in the first two years I've had my Valk. The electrical problems in particular are a real PITA. That's all I have to say about thayatttt.
CoachDoc
'05 Goldwing
'74 CB550K
« Reply #17 on: May 28, 2014, 08:43:04 PM »
Hang in there Coach I have two Valks and I guess I am the lucky one and have never had a problem of any kind with either. Ride safe cooldude
CoachDoc
San Diego, CA
« Reply #18 on: May 28, 2014, 09:46:10 PM »
Thanks, Bighead. Maybe some of your good fortune Valk-wise will rub off on me.
CoachDoc
'05 Goldwing
'74 CB550K
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #19 on: May 29, 2014, 09:49:53 AM »
The title says, "FIXED" but I don't see how you did it....
I hate sand....sand SUCKS!
I wear a helmet....."I'd rather have brains in my head than wind in my hair"
1999 Valk I/S
2000 Valk I/S
2001 BMW K1200 LTE (sold)
2002 FLHRSEI (for sale)
2006 FLHCTUI (sold)
Bone
« Reply #20 on: May 29, 2014, 10:35:50 AM »
Reply #16
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #21 on: May 29, 2014, 10:49:13 AM »
Reply #16
Great. Thanks.....one more reason I don't hunt snakes for a living.......
1999 Valk I/S
2000 Valk I/S
2006 FLHCTUI (sold)
CoachDoc
San Diego, CA
« Reply #22 on: May 29, 2014, 02:25:55 PM »
I replaced the starter switch. Fired up right away afterwards, with tach and headlight working again. Afterwards I cleaned all the battery cable attachments, especially the ground strap and it's contact point. I also cleaned all the fuse holders, trying to get ahead of future problems.
I'd love for somebody to refer to the wiring diagrams and explain to me like I'm six years old the specific connection between the starter switch and the tach. I still don't see it when I trace the wiring on the diagram. Thanks for all the help and replies.
CoachDoc
'05 Goldwing
'74 CB550K
Grandpot
Fort Mill, South Carolina
« Reply #23 on: May 29, 2014, 03:12:19 PM »
Coachdoc:
On sheet 1 of the prints, the ignition switch goes to 10A Tail Meter fuse which then goes to SP8 and then to Sheet 6.  On sheet 6, SP30 supplies 12V and branches at SP30 to sheet 5.  On sheet 5 you can see where SP30 supplies 12V to the tach.   Cheesy
CoachDoc
San Diego, CA
« Reply #24 on: May 29, 2014, 05:02:13 PM »
Coachdoc:
Thanks for the info. I'll see how that looks on the expanded 1 page wiring schematic that comes in the shop manual.
CoachDoc
'05 Goldwing
'74 CB550K
Grandpot
« Reply #25 on: May 29, 2014, 05:12:05 PM »
I may have misunderstood.  When you said Starter Switch did you mean the Starter Button or the Ignition Switch?  The Starter Button only pulls in the Starter Solenoid and disconnects the Headlight momentarily.
CoachDoc
San Diego, CA
« Reply #26 on: May 29, 2014, 08:01:41 PM »
Yes, I realized after the fact that you were referring to the ignition switch. What I replaced was the starter/kill switch combo on the right handlebar. If you have the time and the intellectual curiosity, see if you can figure out how that combo gets involved with the tach.
CoachDoc
'05 Goldwing
'74 CB550K
Grandpot
« Reply #27 on: May 30, 2014, 04:40:21 AM »
Ok, the Kill switch makes more sense.
On Sheet 5, 12V takes the following path:
10A Ignition fuse
SP1
SP2
Into the Bank Angle sensor
Out the Bank Angle sensor on the Black/Lt Green wire
To the Engine Stop switch
Out the Engine Stop switch on the Black/White wire
SP27
Into the Ignition Control Module on pin 4
Out the Ignition Control Module on pin 16
Ends in the Tach.
CoachDoc
San Diego, CA
« Reply #28 on: May 30, 2014, 11:08:06 AM »
Yeah, Grandpot, looks like you've nailed it. Great sleuthing and thanks.
CoachDoc
'05 Goldwing
'74 CB550K
