November 26, 2025, 01:59:07 AM
I want to mount red LED lights on my 98 tourer
Topic: I want to mount red LED lights on my 98 tourer (Read 702 times)
Bonzo
May 27, 2014, 04:59:57 PM »
On the back bottom of the bags. I do not want to drill through the fiber glass. I am trying to find hollow bolts for where the bags mount to the rails. Any thoughts?
Woops, I'm sorry.
Re: I want to mount red LED lights on my 98 tourer
May 27, 2014, 05:19:27 PM »
some nuts and bolts, in a drill press, and drill it through yourself?
I've never heard such a thin that you could buy.
Do they have to be wired through the bag? There is no power there right now.
May 27, 2014, 05:26:48 PM »
With tail lights, higher is better. What about a brighter single light up on the sissy bar? (I've often wondered why more folks don't mount extras there; just because you have to hide a wire coming down one upright?)
Also, I have seen plenty of flush mount LEDs that attach with double sided tape and no hole even necessary (unless you want a small hole for the wire) (they weigh almost nothing). If mounted at bottom of bags, the wire could run underneath, and no hole in the bags at all.
tank_post142
south florida
May 27, 2014, 05:54:01 PM »
hundreds on ebay
I got a rock
VRCCDS0246
semper5
Flint, Michigan
May 27, 2014, 06:41:22 PM »
I just recently mounted red LED's on the sissy-bar, I would post pictures but the forum here is not conducive to an easy method of picture-posting...
I used existing holes to run my wires, but ran the wire up under the passenger seat, and had ti zip-tie the wire to hold it. The LEDs have an adhesive backing which holds to the sissy bar. If I could find a putty of some sort to hold the wire, that might let me get rid of one lonely zip-tie.
Bonzo
May 28, 2014, 06:25:18 AM »
Hollow bolts and disconnectable connection in the bag. Here is an example of a "Hollow bolt
http://www.kuryakyn.com/Products/496/Replacement-38-16-x-1-12-Hollow-Bolts
I saw a lot of led panels, I am leaning toward a truck product, the entire back is a water-proof adhesive. (No connection with Kuryakyn)
Woops, I'm sorry.
=> InZane XXV
