November 26, 2025, 01:59:06 AM *
Author Topic: Alternator on I/S  (Read 916 times)
hoosier jaybird
NE IN.
« on: May 28, 2014, 01:38:44 PM »
I suspect my alternator may be getting weak. 12.7 volts output tops. The G/W alternator mentioned in Jeff's crossover listing says the 97 aspencade alternator will work but has to have the cover rotated to mount up to the Valk. What is the amp output for that particular alternator vs the Valk OEM. I have looked back at past posts and there seems to be other options but not sure if they are viable. Any suggestions? I would at least like to carry an extra one to go to InZane. Thanks, Jaybird.
Red Diamond
Beaumont, Texas
« Reply #1 on: May 28, 2014, 02:01:58 PM »
The output is the same, just remove the three screws on the front, rotate the front, not the rear to match the mounting position of the Valkyrie alternator and install it. Any GW alternator from about '90-2K will work.
« Reply #2 on: May 28, 2014, 03:29:04 PM »
You just may be actually reading the battery voltage and the alternator could be dead.
In any case, what you have is bad.
MARS will work with you to get on the road fast. Give him a call!
Many on this forum can vouch for MARS as I do.
« Reply #3 on: May 28, 2014, 03:31:22 PM »
how many miles? when did u last replace the alternator brushes? most recommend 50-60k miles to be changed out
Highbinder
Bastian/Tazewell,VA.
« Reply #4 on: May 28, 2014, 04:26:26 PM »
Sears sells the alternator for the Valk for about $160...check it out...
http://www.sears.com/rareelectrical-new-12v-oem-alternator-honda-valkyrie-interstate/p-SPM6199819505
hoosier jaybird
NE IN.
« Reply #5 on: May 28, 2014, 05:56:21 PM »
Thanks for the info all. I talked to Ken at MARS and I think we have a solution. I am looking at his 65 amp upgrade. He seems to be a helpful fellow. Jaybird.
« Reply #6 on: May 28, 2014, 06:25:52 PM »
       When the alt took a dump on my I/S I went with the M A R S at the behest of this very board. AND I'm pleased that I did-new rebuilt alt and a BRAND NEW Yuasa battery. Still cranking out the life blood of the battery. RIDE SAFE.
