November 26, 2025, 01:58:44 AM *
Author Topic: 4 degree trigger plates, good or bad?  (Read 690 times)
Eric58701
Minot NorthDakota
« on: May 29, 2014, 07:56:40 PM »
i have seen talk about and seen a couple for sale on ebay, but before i make the purchase i would like to know the pros and cons about them? thanks
« Reply #1 on: May 29, 2014, 08:16:10 PM »
Been here a day or 2 and from what I can tell-some swear by em and some swear at em and some are happy as piglets in new kaka.  2funny Research here on the tech board. Some have stated that after a trigger wheel install higher octane gasoline was needed. My I/S runs fine the way it is I M H O.  cooldude NO-I have not installed an other than stock trigger wheel. Hope I've been some help for ya!!  coolsmiley RIDE SAFE.
« Reply #2 on: May 29, 2014, 08:22:46 PM »
IMHO, Shakespeare had it right.
big poppa pump
San Antonio, TX
« Reply #3 on: May 29, 2014, 08:23:05 PM »
Did the simple ECT mod with a 1K resistor instead of a 4 degree TW. The ECT mod tapers of the advance above 3.5k RPM, which means you don't loose any top-end power. Also have an I/S ICM installed along with this.
« Last Edit: May 29, 2014, 08:46:40 PM by big poppa pump » Logged
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #4 on: May 29, 2014, 10:57:00 PM »
I put a 6* wheel in MGM at about 13,000 miles.    242K+ and it is still there.   Running 89 octane fuel and don't have any pinging.
Interstate springs in the carbs was the only mods I did later.
MGM runs hard, pulls like a team of Draft horses, and will do it again the next day.
I never went for the ICM modifications.    Too much work to get it changed in my book.
Would I do the wheel change again, YES..
« Last Edit: May 29, 2014, 10:58:32 PM by R J » Logged
rocketray
« Reply #5 on: May 30, 2014, 12:34:00 AM »
the valkyrie stock ignition curve can use the additional advance at lower rpm but it has the perfect ignition advance at higher rpm so adding the trigger wheel is good if you like more lower end hp/torque but if you twist it up high it will have too much advance and less power....how do you ride answers the question....cruiser or sportier
