February 08, 2026, 09:05:39 PM *
Author Topic: Clunk heard from somewhere(Drive shaft or Final drive)  (Read 1204 times)
Louis Durocher
'99 Interstate
Montreal,Canada
« on: May 31, 2014, 08:25:26 PM »
Hi everyone,
             when i release the clutch on a street corner i can hear a clunk somewhere coming from the driveshaft or final drive.Does it ring a bell for somebody. Old parts semms to be hard to find in good condition.
Thank's for the help.
I am planning to take everything apart tomorrow. Wink
Have a safe ride
Michvalk
Remus, Mi
« Reply #1 on: June 01, 2014, 02:56:17 AM »
U joint, or pinion splines. Pull the rear end and pull the driveshaft from the Pinion. Or could be extremely worn dampers in the wheel cooldude
« Reply #2 on: June 01, 2014, 04:35:56 AM »
My rides:
« Reply #3 on: June 01, 2014, 04:38:02 AM »
Check for worn dampeners in the wheel while its broke down as well.
pancho
Bonanza Arkansas
« Reply #4 on: June 01, 2014, 05:52:38 AM »
Put the ujoint in a vice and channel locks on the other end to check it for play while it is out, don't get fooled just because it feels good while twisting it in your hands.
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #5 on: June 01, 2014, 06:50:59 AM »
I checked out the drive shaft this morning prior to dismantle everything and the universal joint is all wornd out.When i bought this bike the stealer said that everything have been inspected and repaired if necessary. It isn't the case. I wrote them a nice complaint letter. Waiting to get an answer.
I will let you know what is happening
Have a safe ride
MP
North Dakota
« Reply #6 on: June 01, 2014, 08:20:57 AM »
Good Luck with that!
Even if they checked and replaced a lot of stuff, I doubt many would include the U-joint in "everything".  Simple fix.  Glad you caught it before it grenaded on a long trip.
MP
"Ridin' with Cycho"
Jack B
Two Rivers Wis
« Reply #7 on: June 01, 2014, 11:19:53 AM »
 It's hard to check a u joint with taking it apart
Let’s RIDE
« Reply #8 on: June 02, 2014, 06:41:13 AM »
Here's some good advice if you plan on keeping the bike.
Buy two.
One for now, and one for later.
They will not get any easier to find.
We've already had that lesson.
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #9 on: June 11, 2014, 05:48:11 PM »
Job is done. Replaced the ujoint, driveshaft and coupler. The dealer offered me a discount of 20% on all parts. Took me 4 hours to do everything. Now it runs smooth. Smiley
Have a safe ride
« Reply #10 on: June 11, 2014, 06:45:01 PM »
Louis do you think the u-joint was the issue or a combination u-joint, worn shaft splines and pinion cup? Just curious.  Smiley
Glad she is smooth again.
My rides:
Louis Durocher
'99 Interstate
Montreal,Canada
« Reply #11 on: June 12, 2014, 03:16:09 PM »
I Think it is a combination.The way i see it the drive shaft wobble destroyed the ujoint. He was not rusted but two of the caps were loose in the yoke
Have a safe ride
