January 29, 2026, 08:30:28 AM *
Author Topic: honda gp4 synthetic oil  (Read 4006 times)
zoltan57
Denver, Colorado
« on: August 04, 2009, 01:19:21 PM »
3 weeks a go i bought the honda gp4 synthetic/petroleum blend without moly sae 10w-40 sj since then when i engage my clutch from 1st to 2nd it slips/skips on ocassions and also i noticed alittle more exhaust smell .. previous oil was the standard type and i had no slippage in shifting or exhaust smell... has anyone ever had this problem or is common for this oil as it breaks in ..or do i have a completely different issue..... thanks in advance...emrik
« Reply #1 on: August 04, 2009, 02:26:28 PM »
Sounds like a failure to get your fingers fully off the lever.
I've run synthetic oil (Mobil 1) for well over 200K miles with no problem or slippage.    Did junk out 1 clutch basket.
asfltdncr
« Reply #2 on: August 04, 2009, 04:07:33 PM »
I would drain it and get some Rotella from Wally World.
« Reply #3 on: August 04, 2009, 07:55:10 PM »
Mobil 20-50 motorcycle v-twin oil and a pure one filter here.  So far, zero problems.
« Reply #4 on: August 05, 2009, 08:26:29 AM »
honda oils tested to be one of the worst oils to use by Motorcycle consumer news a few yrs ago.
zoltan57
Denver, Colorado
« Reply #5 on: August 08, 2009, 10:40:44 PM »
ok.. so the honda oil gp4 sucks,,, what brand and type can i buy off the shelf ....
thanks
« Reply #6 on: August 09, 2009, 04:45:45 PM »
thanks
rotella 5w40 is a group III oil which is classified by law as a syn and actually has specs similar to the group IV/V mixtures on the market.  any 15w40. I have mobil delvac 15w40 in the bike right now.  Chevon Delo 15w40 has more moly than the others, but the level is still low enough to not affect the clutch.
I also use AMSOIL 10w40, the one for cars as it has always been rated for cycles, started using it in the mid '80s. Now they sell more $$$ cycle specific oil, a little bit better specs but much more $$$.
my next change I will be using Amsoil 10w30/30HD diesel oil.
and of course MOBIL 1 is used by a lot of people.
zoltan57
Denver, Colorado
« Reply #7 on: August 09, 2009, 08:30:20 PM »
which type of mobil one do i use........ also some one gave me 4 quarts of amsoil synthetic 10w-40 motorcycle oil which i havent used yet its been sitting on the shelf... is type good also?
thanks
Mr.BubblesVRCCDS0008
« Reply #8 on: August 10, 2009, 09:45:45 AM »
mobil one 15W50 is the automotive grade to get if that's what you want to run. It is the only one without friction reducing agents. This is what I run is my bikes.
