April 29, 2026, 07:01:59 AM *
Author Topic: Anti dive valve disable F6B/Goldwing not Valkyrie  (Read 7322 times)
Warlock
Magnolia, Ms
« on: June 04, 2014, 08:24:11 AM »
Looks like the didn't install the anti dive valve in the new Valkyrie's, wise decission, but the make a kit to disable them on the F6B and goldwings. The reason I like them disable is they can make the front left fork leak. When you apply the brakes it activates a valve that doesn't let the fork recoil like it should. They claim it helps the bike from diving when braking. I put the kit on mine and noticed a better ride. It does dive a little when braking, but after riding all these years without this thing was no big deal. You can take the valve loose and add a couple washers in it or use the kit. I used the kit for mine. Takes about 10 minutes to do the job.
http://wingstuff.com/products/32921-anti-dive-fork-valve-shim-w-screws?from_search=1
David
