February 08, 2026, 09:05:45 PM *
Author Topic: fork leak  (Read 954 times)
b1rks
« on: June 05, 2014, 05:32:40 PM »
noticed a little leakage on the  lower section of my fork. Running down I assume. I have been told you sometimes you a little crud around the seal inbetween seal n fork causing leakage. Remove dust cover carfully clean? Anybody have any experience with this  Rather try the cheap fix before the expensive one. I relize forks are different   Thanks
Bugslayer
Lubbock, Texas
« Reply #1 on: June 05, 2014, 05:59:17 PM »
You've probably got a little dirt in your fork seal. I've had great luck with Seal Mates. I still have a set of new seals in my tool box that I ended up not needing. I would recommend trying em out.
http://sealmate.net/
« Reply #2 on: June 05, 2014, 10:08:46 PM »
I ordered a Seal Doctor the other day.  Haven't received it yet so I'm not sure how well it works yet, but I'm thinking it'll work better than the flimsy Seal Mate.
http://www.riskracing.com/pages/Seal_Doctor_Page.html
Risk Racing Seal Doctor - Fix leaky fork seals in second...powered by Aeva
PAVALKER
Pittsburgh, Pa
« Reply #3 on: June 06, 2014, 04:49:26 AM »
Seal Dr sales person was much better looking than the other one from Seal Mate and seemed to know the diff between a dust and oil seal and didn't get confused (either that or she reads the script much better).  Did I mention I would rather have her work on my seal?   That's what I'm calling it today.... cooldude
John
b1rks
« Reply #4 on: June 06, 2014, 05:31:53 AM »
thanks for great advice
« Reply #5 on: June 06, 2014, 08:16:05 AM »
If you have some 35mm negatives laying around you can try those. It's worked a couple times for me cooldude
CASABROKER
« Reply #6 on: June 06, 2014, 08:31:09 AM »
+1 on the 35mm film  just cut the tracks of the sides.
SpidyJ
Murrells Inlet
« Reply #7 on: June 06, 2014, 01:31:39 PM »
Seal mates +1000!
1999 Fast Black Interstate
Peace,
johnnywebb
b1rks
« Reply #8 on: June 06, 2014, 06:08:14 PM »
Thanks try the 35mm thing   if not check out seal mate site. Allways sucks living in Canada ordering stuff. On another note Cycle Canada did a nice article on the original Valk. Talked to the head of one of the Canadian chapters. Cycle Canada good magazine.
« Reply #9 on: June 06, 2014, 06:17:30 PM »
Cutting an approximate shape of a Sealmate from a plastic soda bottle will probably work better than film.
b1rks
« Reply #10 on: June 11, 2014, 10:24:52 AM »
I took dust shield off. Which had a tear in it. Which was collecting gunk over the years. (probally the cause of leak). Cleaned that out  Was going to put some sort of sealant on  tear  (changed my mind not sure what to use). Used the bottle idea without hock area (didn't want to tear anything  ). Good amount of flued came out  Put every thing back together. And neglected to move forks up and down. To reseat forks (dumb ass). probally low on flued  Heading to dover toommorow. Oh well try again on weekend.
olddog1946
Moses Lake, Wa
« Reply #11 on: June 11, 2014, 10:52:14 AM »
If your dust seal was split, I'd be willing to bet you won't be able to stop that leak without replacing the fork seal and dust shield. Do the on the bike replacement, so easy to do, I was amazed, took just over an hour a side and we did each side on different days and after riding.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
b1rks
« Reply #12 on: June 11, 2014, 04:10:43 PM »
Any info on this site on the On Bike Fork Seal and Dust Shield change. I was looking in Valk Book on replacing seal Definatly more than hour job.
vanagon40
Greenwood, IN
« Reply #13 on: June 11, 2014, 06:35:37 PM »
Check out this link.  I did not read all the posts, but might put you in the right direction.  Good luck,
b1rks
« Reply #14 on: June 12, 2014, 03:41:23 AM »
