February 08, 2026, 09:05:43 PM *
Author Topic: Yeah, I know...Pingel  (Read 1047 times)
SpidyJ
Murrells Inlet
« on: June 06, 2014, 01:14:41 PM »
But I want to keep the OEM petcock!!
I converted the OEM to manual and tested it with the old suck test and it was shutting off just fine.
I tested it in the off position when I first did the job. It took a while but it finally stalled.
I pulled into the garage last night and went to shut it off..........it was already in the off position.....duhuh!?!
I have a Dan Marc and I always tap the starter button so I'm not real worried about hydrolok but I wonder if I did something wrong.  I cut both diaphragms out and threw away the little piston and the spring.
What is wrong???
« Last Edit: June 06, 2014, 01:16:24 PM by SpidyJ » Logged
1999 Fast Black Interstate
Peace,
johnnywebb
« Reply #1 on: June 06, 2014, 01:49:54 PM »
What is wrong ?
Easy, the design. If the switch/valve is not positioned exactly ,which also requires the nose and mouth to be contorted just right, it will not seal. The ball and seat as designed leaves a bit to be desired.
Pingle now makes a vacuum unit.
« Reply #2 on: June 06, 2014, 02:09:13 PM »
What is wrong???
What is wrong is the design of the OE valve.  Its a low quality item at best.  Now you tear it part and change its function but its still a low quality part.
The only real good reason for wanting to keep the OE parts is because you have the chrome engine hanger and there will be a big hole.  So sell the chrome hangers to pay for the new quality valve (there are others besides Pingel) I have the Pingel and am very happy with it
3W-lonerider
Shippensburg Pa
« Reply #3 on: June 07, 2014, 03:30:01 AM »
if your running a dan mark. I wouldn't worry wether or not that petcock is shutting off.
I'm running a pingle set to reserve all the time and an electric fuel shutoff after that.
been that way for 8 years. have yet to have a problem. my covers don't have a hole in them so I couldn't get to the petcock even if I tried without removing the whole cover.
Mr.BubblesVRCCDS0008
« Reply #4 on: June 07, 2014, 10:48:40 AM »
I converted my stock petcock to a manual by removing the diaphragm, spring, and piston and placing a thick piece of gasket material in between the pieces where the diaphragm was. I've ran this setup for over 5 yrs now. The on, off and res still function as normal.
« Reply #5 on: June 07, 2014, 11:23:17 AM »
I converted the OEM valve to manual years ago after the first fuel lock, it was a royal PITA as they don't seat well.
Installed the Pingle. Just my choice whether right or wrong.
But, with an electric solenoid/shut-off, why worry ? Let the original leak, should bother a thing.
