February 08, 2026, 09:05:36 PM *
Author Topic: Pilot screw o'rings.  (Read 1383 times)
oldfella
« on: June 10, 2014, 06:10:06 PM »
There is a o'ring kit available for the pilot scrwes of a valkyrie but none of the sellers send to Australia. Just wondering if any one can tell me the correct sizes of the o'rings so that I can purchase them individually.
« Reply #1 on: June 10, 2014, 10:06:44 PM »
When you find the size, get them locally in Viton or silicone material. That way they will stand up to gasoline.
« Reply #2 on: June 11, 2014, 03:44:17 AM »
no silicone, it is a poor choice for gasoline, Buna-n is oem material Viton is best
http://www.efunda.com/designstandards/oring/oring_chemical.cfm?SM=none&SC=Gasoline%2C%20Automotive#mat
BonS
Blue Springs, MO
« Reply #3 on: June 11, 2014, 05:24:47 AM »
I measured the O-rings that I received from Redeye with my Mitutoyo digital calipers. The OD is 0.189" or 4.8 mm. The ID is 0.1045" or 2.65 mm. The cross section is 0.045" or 1.14 mm. Hope this helps.
Blackduck
West Australia
« Reply #4 on: June 11, 2014, 05:48:48 AM »
Could be a little hard to find, my references come up with 1mm or 1.5mm cross section.
The 1 mm has a tolerance of +/- .05 mm which could get it to 1.1
1mm is a German spec.
Blackduck
West Australia
« Reply #5 on: June 11, 2014, 06:14:14 AM »
Check Redeye's site, has Ebay and another site that does list International shipping. Bag C with O rings, washers and the springs
BonS
Blue Springs, MO
« Reply #6 on: June 11, 2014, 09:45:53 AM »
Yup, I measured the Bag C O-rings.
97Valk_CT_Euless
Euless Tx
« Reply #7 on: June 13, 2014, 05:01:09 AM »
Since Redeye is apparently closed up i ordered these from McMaster Carr.
19263K546 Metric Viton(R) Fluoroelastomer O-Ring, 1 mm Width, 2.5 mm ID, packs of 25
3.38
per pack
That's $3.38 US.  I asssume they ship overseas? Dunno.  Been around forever, you might even have them there.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #8 on: June 13, 2014, 06:49:57 AM »
Red Eye is not closed up. I spoke to him the other day and he will be back on the 18 Of June
97Valk_CT_Euless
Euless Tx
« Reply #9 on: June 13, 2014, 07:27:28 AM »
Sorry.  Didn't mean that, though I can see that's what I said.  Wasn't sure how fast they were needed.
Personally I'd rather order the whole kit from Redeye, I don't need 25 o-rings, but though our friend in Australia might be able to get ahold of them quicker this way.
