February 08, 2026, 09:05:49 PM *
Author Topic: Tire size question  (Read 749 times)
Srao
Kansas City
« on: June 11, 2014, 08:47:30 AM »
My speedo is about 3 mph over the actual speed. I figured out a tire sized that will drop my speed reading by 1.8% about 1 mph at 60, but I want some opinions on if it will fit well or not.
The tire I'm wanting to put on is a Bridgestone 240/55-16. It will be about 1/2 inch taller overall and 1 inch wider than the stock 180/70-16 tire.
Opinions? Experience? Knowledge? Suggestions?
" I aim to misbehave! " - Malcolm Reynolds, Fire Fly
rhinor61
Northern California
« Reply #1 on: June 11, 2014, 09:06:55 AM »
The speedometer drive is located on the Front tire,
changing the rear tire will have no effect on your speedometer.
Stock tire sizes..
front tire 150/80-R17
rear tire  180/70-R16
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
Farther
Quimper Peninsula, WA
« Reply #2 on: June 11, 2014, 09:17:03 AM »
60 mm is about 2.4 inches (240-180=60).  That may cause you significant rubbing.
~Farther
Srao
Kansas City
« Reply #3 on: June 11, 2014, 10:40:46 AM »
Ah well that makes sense. Thanks for the info. that changes everything.
The ratio for the sidewall is lower making the overall width difference only 1 inch. maybe a hair less.
Thanks guys now I'll just get the 200/60-16 that was recommended to me already.
97Valk_CT_Euless
Euless Tx
« Reply #4 on: June 11, 2014, 02:05:20 PM »
I put a 200/60 on and there was very little space between the swingarm and the tire.  Enough, but the 240 wide.. That's 20mm on a side wider then the 200. There's no way.
I think you'll find that the width (240) is the width. (Some difference between manufacturers, but not much).  The height is defined by the series, based on the width.  Anyway, i think the tire would be unuseable.
I wasn't crazy about the handling of the 200/60.  Made the bike feel like I had to "tip" it into the turn.  WOuldn't think it would make much difference but I could feel it.
It did look badass though!
