February 08, 2026, 10:57:45 PM *
Author Topic: Reverse rotation of a rear tire when mounted to the front?  (Read 3311 times)
quexpress
Montreal, Québec, Canada
« on: June 11, 2014, 04:59:55 PM »
Hi!
I'm just about ready to install a Continental Conti-Go rear tire on the front wheel of my Valk.
As often discussed here and on other forums, it is generally suggested by the manufacturers to reverse the direction of the tire when installing a rear tire in the front. Following is an article written by Avon tires:
http://cyrilhuzeblog.com/2009/08/23/tires-directional-arrows-explained-by-avon-tyres/
Their explanation is quite clear. However I'm tempted to leave this tire in its intended rotation direction because I like the thread pattern. I'm under the impression that the "v pattern" will disperse the water very well.
I believe that most here who have installed rear tires in the front have done so in reversed direction. I'd like to hear about the few who have decided to not reverse the direction.
Are you happy with the results?
Thanks!
Normand
I still have a full deck.
I just shuffle slower ...
Pete
« Reply #1 on: June 11, 2014, 05:32:02 PM »
I have done it both ways and have not noticed any real difference.
saab9k
« Reply #2 on: June 11, 2014, 05:43:49 PM »
It is mostly done on trikes, the added weight/force  when braking.
vanagon40
Greenwood, IN
« Reply #3 on: June 11, 2014, 06:09:12 PM »
I am reluctant to respond because you specifically requested a different response, but I believe if you look at the general “V” pattern, most front tires are the reverse of the rear (and have the narrow point of the "V" up in front).  I know the original Valkyrie tires were reversed “V” patterns.  I have no idea if Gryphon Rider’s theory [link] is correct, but it makes sense to me (and confirms my observations that most motorcycle tires have the point of the “V” pattern pointing up when looking at the front of the bike).
I would add, I have never heard a valid or legitimate explanation or argument for mounting a rear tire in the direction of the arrow when used as a front tire.
I apologize for the non-responsive post.
« Reply #4 on: June 12, 2014, 07:33:11 AM »
I don't subscribe to the "reversing" argument, and more importantly, want to
point out, that the tread designs of tires are made to help avoid aquaplaning on wet roads
and that you would defeat the water shedding characteristics of the tire by installing the tire backwards.
quexpress
« Reply #5 on: June 13, 2014, 12:52:25 PM »
IMHO I had to keep 2 things in mind:
1. How the water comes off the tire.
2. The direction of the lamination.
I try very hard to avoid riding in the rain because I do not enjoy it. In my case, this water displacement is therefore not a big thing.
I have never heard of a motorcycle tire de-laminating because a rear tire was installed on the front WITHOUT reversing it. IMHO the companies say this for liability purposes.
However, I have nothing to lose by trying it in reverse direction.
I therefore installed it in reverse direction.
Thanks for your input!
Normand
« Reply #6 on: June 13, 2014, 01:32:22 PM »
Rd,
all I can say is I installed my conti-go in reverse direction as this put the tread design in the same direction as the front metzler I took off.
quexpress
« Reply #7 on: June 13, 2014, 06:36:41 PM »
Rd,
This is what it looks like on my Valk.
Thanks CA!
« Reply #8 on: June 14, 2014, 02:44:02 PM »
Rd,
Thanks CA!
anytime, anyplace
looks fantastic.
wish my forks were that shinny.  :'(
PhredValk
Edmonton, Alberta, Canada
« Reply #9 on: June 14, 2014, 05:18:53 PM »
I like Dunlop D404 bias rear tires up front. The first went for two years and the second I put on last spring, both in normal direction. I like the water shedding, and have ridden several 7-8 hour days in the rain on my annual pilgrimage to family and friends in Ontario from Alberta. I've read the literature but have yet to hear of any tire de-laminating under stress in any circumstance.
I like the tire, it's great on wet roads and lasts better than 20K miles for about $118.
Fred.
VRCCDS0237
pancho
Bonanza Arkansas
« Reply #10 on: June 15, 2014, 05:56:10 AM »
What are the benefits of running a rear tire on the front?    I mean, why do it?
Karen
Boston MA
« Reply #11 on: June 15, 2014, 06:01:57 AM »
Longer tire wear, rear tires are generally thicker than fronts. Front tires are built to handle braking forces, rears to handle acceleration forces. My Conti Go is backwards on my trike, and I love it.
« Reply #12 on: June 15, 2014, 11:57:42 AM »
Just ordered a Michelin Pilot Activ rear. I`ll decide which way I`m going to put it on when I look it over cooldude
quexpress
« Reply #13 on: June 15, 2014, 04:47:50 PM »
We are on the same page Fred!
I have reversed it only because I had nothing to lose. However I might try it in the "normal direction" next time.
Thanks!
quexpress
« Reply #14 on: June 15, 2014, 04:50:00 PM »
Goldwing riders, especially the ones with trikes, like this tire very much. I'm anxious to hear about your results, impressions, etc.
« Reply #15 on: June 15, 2014, 09:23:39 PM »
Yeah that's what got me thinking about this tire. I've probably still got 2k left on the metzler that's on now, but I'll let you know what I think after some time cooldude
« Reply #16 on: June 16, 2014, 03:34:19 PM »
the miche web site shows terrible wet traction and comfort.
« Reply #17 on: June 16, 2014, 04:38:57 PM »
I guess I didn't research it so well. The wet traction won't be a problem as it only rains once a year here 2funny. What does the bad comfort mean? Stiff, harsh ride? Hopefully it will work out.
