February 08, 2026, 09:06:28 PM *
Author Topic: Headlight wont work  (Read 716 times)
lgibson
« on: June 12, 2014, 10:19:02 AM »
On my 1999 Valkeryie my main headlight and the 2 ad on driving lights went out and I cannot find the problem. Can it be in the ignition switch, high beam low beam switch or starter switch? The ignition is just an on, off switch so I have ruled that out. I have checked all fuses. I have replaced a bunch of butt connectors that looked old. Also the horn stopped working a few days before and the right running light don't come on when you turn the key on. PLEASE HELP.
Troystg
DC
« Reply #1 on: June 12, 2014, 10:33:02 AM »
Same reply you will hear several times,  did you clean and test the start switch?  Is the extra lights on a relay?
Troy
« Reply #2 on: June 12, 2014, 11:21:38 AM »
And if its a STD/Your model there is an article in Shop Talk or archives on installing a relay if you don't already have one installed.
I also don't know what you mean by not being able to find the problem. How far have you looked ? And, where do have and where don't you have power ?
lgibson
« Reply #3 on: June 12, 2014, 07:45:56 PM »
There is some kind of relay behind the headlight. I did take the starter switch apart. It has several problems that JUST started. I'm just going to take it to the shop. There isn't anyone around Wichita Falls that will work on them.
