February 08, 2026, 09:06:27 PM *
Author Topic: Headlight Bulb Change Opinions Needed  (Read 901 times)
Harv
One Bad Motor Scooter
Des Moines, Iowa
« on: June 13, 2014, 05:23:02 PM »
I just replaced my headlight bulb with a Sylvania Ultrastar. I got it out of the package and installed in the headlight without touching it. Should I have cleaned it with alcohol anyway just to make sure it hadn't been contaminated from the factory? I haven't mounted the headlight assembly back on the bike yet so it would be easy to clean it if I should. Thanks for any replies.
Harv Wink
PAVALKER
Pittsburgh, Pa
« Reply #1 on: June 13, 2014, 05:52:13 PM »
Should be fine as long as YOU didn't touch it with bare fingers or put oil on it somehow.
John
« Reply #2 on: June 13, 2014, 09:19:45 PM »
Harv, knowing you, I'd suggest ya clean it before you put it in place and turn it on.
Harv
Des Moines, Iowa
« Reply #3 on: June 13, 2014, 09:27:39 PM »
I didn't even come close to touching the bulb RJ  tickedoff .
Harv Wink
« Reply #4 on: June 14, 2014, 05:23:48 AM »
But how about someone touching it when it was boxed up at the factory?
I'd clean it just for sheets and grins to be safe.
PAVALKER
Pittsburgh, Pa
« Reply #5 on: June 15, 2014, 06:33:40 AM »
Better safe than sorry.....   Ya know there is probably a disgruntled Osram/Sylvania employee randomly opening those machine handled bulbs and packages and rubbing them all over his body to get them coated with human body oils.   Grin
http://m.youtube.com/watch?v=JU_s14hYURA
John
