February 08, 2026, 09:05:34 PM
rear wheel won't seat in the pumpkin *FIXED*
Topic: rear wheel won't seat in the pumpkin *FIXED* (Read 772 times)
Jetflyer
Vale, North Carolina
June 13, 2014, 06:56:28 PM »
I took my rear wheel off to replace the tire.
Greased splines as per Honda.
Replaced all three O rings and the thrust washer.
THE 4 FINAL DRIVE NUTS ARE LOOSE.
My wheel will not fully seat back into the pumpkin completely enough to get the spacer and brake both back on the axle. I can't seem to get the final 1/4 inch of the wheel to seat in the splines.
Thanks in advance for your suggestions.
Last Edit: June 13, 2014, 10:34:21 PM by Jetflyer
I'm either driving a Valkyrie or an Airbus... it just depends on the day of the week.
Re: rear wheel won't seat in the pumpkin
June 13, 2014, 07:35:37 PM »
Yes: New O rings can be tough. Sit on the right side and reach around the swingarm. Pull hard as you lean your shoulders against the bike as a counter pressure. Oh yeah, lightly grease the O ring.
June 13, 2014, 07:36:12 PM »
Which o-rings are you using? Somebody else had trouble recently with I think red eye polyurethane orings.
Jetflyer
June 13, 2014, 09:57:18 PM »
Problem solved.
A closer look at the Honda service manual revealed that I had the spacer inserted on the axle backwards. Viola!!
Everything fit and torqued, then tightened the 4 final drive nuts last.
Cheers!
Last Edit: June 13, 2014, 10:36:26 PM by Jetflyer
