February 08, 2026, 10:58:02 PM
Gas Smell
Topic: Gas Smell (Read 1093 times)
Hef
Opdyke, IL 62872
Gas Smell
June 17, 2014, 07:43:16 PM »
I have a strong gas smell coming from my Valkyrie after riding for any distance. There is nothing dripping on the ground and cannot find anything on or around the engine. The first time it happened I pulled all the plugs to make sure I wasn't headed for the dreaded hydrolock. Everything looked good. Anyone had this problem? TIA
big poppa pump
San Antonio, TX
Re: Gas Smell
June 17, 2014, 10:12:17 PM »
Check your intake O-rings.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Re: Gas Smell
June 18, 2014, 04:30:34 AM »
Many have found the smell coming from a failing gas cap gasket.
Some have added/sistered a home made gasket of bicycle inner-tube rubber (or something) to complete the seal. Do not drop a tiny screw in the tank.
Re: Gas Smell
June 18, 2014, 06:34:57 AM »
Prob gas cap like jess said. I usually smell a little before going on resv.
Farther
Quimper Peninsula, WA
Re: Gas Smell
June 19, 2014, 07:06:37 AM »
Quote from: fudgie on June 18, 2014, 06:34:57 AM
Most likely a hygiene problem.
~Farther
wiggydotcom
Yorkville, Illinois
Re: Gas Smell
June 20, 2014, 09:13:36 PM »
One other area to check that can give off a strong gas smell is the clamps on the intake tubes...check both the upper and lower clamps. You might find several that are pretty loose and causing the gas smell.
VRCC #10177
VRCCDS #239
Re: Gas Smell
Reply #6 on:
June 20, 2014, 11:45:22 PM »
Quote from: Farther on June 19, 2014, 07:06:37 AM
Jack B
Two Rivers Wis
Re: Gas Smell
Reply #7 on:
June 21, 2014, 04:27:30 AM »
Quote from: Jess from VA on June 18, 2014, 04:30:34 AM
Same here added a gasket and no more gas smell.
Let’s RIDE
Brian
Monroe, NC
Re: Gas Smell
Reply #8 on:
June 23, 2014, 05:25:17 PM »
The fuel rail O-rings going bad could give ya the odor before seeing gas puddle up on the engine or drip. Also place a piece of tape over the key hole in the gas cap. I get some odor out there every once in a while.
Pete
Re: Gas Smell
Reply #9 on:
June 23, 2014, 06:10:29 PM »
Soak the gas cap seals in Silicone, that will swell them for a better seal.
