February 08, 2026, 10:58:00 PM *
Author Topic: qusetion  (Read 925 times)
fubar606
eastern washington
« on: June 18, 2014, 09:33:08 PM »
I did the hub and the 3 orings  left the 4 driveline bolts the last thing tighten greased  and oiled every thing last fall , now I decide to put new rubber on my fat girl do I half to loosen the 4 bolts and leave them the last thing to tighten up ...or just pull the tire and wheel off and do them and put it back on   cooldude cooldude
life is sexually transmitted and always fatal
« Reply #1 on: June 19, 2014, 03:37:57 AM »
I loosen the 4 bolts/nuts. It doesn't take long.
« Reply #2 on: June 19, 2014, 04:34:13 AM »
+1
JC
The Beast
Franklin, TN
« Reply #3 on: June 19, 2014, 06:47:32 AM »
+1
+2  cooldude
pancho
Bonanza Arkansas
« Reply #4 on: June 19, 2014, 07:07:08 AM »
It insures good alignment of everything that is along the rear axle compression line,, just a good habit to get into.
KSDragonRider
Salina, KS
« Reply #5 on: June 19, 2014, 01:43:52 PM »
I know you just did it in the fall, but when you pull your tire, take those 4 nuts off and pull your pumkin with your tire.  Then look over everything again.
I have not seen anyone say that they had a failure by checking and regreasing the rear end, it was always the other way around.  Really, it does not take to much longer than just doing the tire change.  I think it adds half an hour at my house, and well worth the piece of mind.
Oh, and throw some bearings and seals in that wheel if you have not before. I keep hearing about guys running them till they go bad. That seems unwise to me.  I changed the tire and did rear end maint on a friends bike this weekend, he had a bad bearing in the rear and did not know it.  He thought it was the old tire causing his feelings.  It made the brake rotor eat into the pads and caliper.  Ate thru new brake pads in less than 5k miles.
I pay about 10 bucks a pop for good quality roller bearings meant to go in high speed-high force load printing equipment (flame on all you that only run honda parts) and then i just change them every 20k miles or when the tire is getting change around that.   So every other bike tire, every car tire change.  Costs me an extra 20 bucks for that tire change, and I dont have to worry about breaking down on the side of the road.
Dalen & Shay -> Salina, KS
VRCC Member #33950
fubar606
eastern washington
« Reply #6 on: June 19, 2014, 04:56:59 PM »
Ok now I feel better I put it on the lift and loosened everything up and retighten in the right order I did have what sounded like the break dragging that's gone and I replaced the shock bushings that mad more of a deference than I thought it would . ready to ride cooldude
