UTAH INFANTRY
« on: June 19, 2014, 09:21:35 AM » |
I recently bought the Ultimate Low boy seat and back rest. I'm a shorter rider about 5'7". I feel like if my bars were pulled back a couple inches I would be in a much more comfortable position.
Any tips?
Recce 1-12INF 4BCT 4ID Operation Enduring Freedom
1986-Jessica Rae Leota-2012 All my Love All my life
wingrider02
« Reply #1 on: June 19, 2014, 09:31:07 AM » |
I just bought a set of Duece risers for my Interstate...they rise up 5.5 inches, and pull back somewhere around 2-3 inches. I currently have higher than stock risers, but feel I am leaning forward a bit much for them.
Farther
« Reply #3 on: June 19, 2014, 11:36:55 AM » |
I too am a short rider and have the risers that RobertC is using. I like them and a very easy install.
Thanks, ~Farther
98pacecar
« Reply #4 on: June 19, 2014, 12:49:56 PM » |
5' 7'' here,,, as well  Here's what ''deuce'' risers look like on my 98   With a Corbin seat, the reach is now MUCH,,,, more comfortable...
matt
« Reply #5 on: June 19, 2014, 03:26:32 PM » |
98pacecar did you have to move cables? And how long ago did you do them? Thanks
98pacecar
« Reply #6 on: June 19, 2014, 03:50:11 PM » |
Yes I did. (3 months ago)  Just pulled the throttle assy off the bars. N' re-ran the stock cables, n' wiring, behind,, the triple tree. See pic.
matt
« Reply #7 on: June 19, 2014, 04:36:14 PM » |
Thanks. No problem like that in pic to me they look close to tank? But thanks for answering
98pacecar
« Reply #8 on: June 20, 2014, 07:28:31 AM » |
No problem,,, what so ever. Everything works n' clears fine..
« Reply #9 on: June 20, 2014, 07:39:56 AM » |
I assume you've loosened the handlebar clamps and played with the bar position already?
matt
« Reply #11 on: June 21, 2014, 03:04:54 AM » |
Well the big issue is po had put some risers on and drilled holes and bars are sitting crooked. Had the bike since 07 every year I bitch about it well finally going to try and fix it. Been doing a little side work and now is the time to at least get stuff together. Thanks again
fantsybikr
« Reply #12 on: June 23, 2014, 11:14:46 AM » |
5' 7'' here,,, as well  Here's what ''deuce'' risers look like on my 98   With a Corbin seat, the reach is now MUCH,,,, more comfortable...  Utah Infantry, I have a set of new never installed risers like 98pacecar shows here..I will make you a good deal on them..I decided not to use them
VRCCDS 0252 VRCC 26284 GWRRA 329832
UTAH INFANTRY
« Reply #13 on: June 23, 2014, 12:02:50 PM » |
fantsybikr, I would have taken you up on that deal but I already ordered them online.
