February 08, 2026, 10:56:18 PM
Speedometer assembly question
Topic: Speedometer assembly question (Read 727 times)
lljjmm
June 19, 2014, 09:37:30 PM »
Does the speedometer assembly on the front axle suppose to move freely?
I just replaced the front tire and everything works, and lines up but I don't remember if the speedometer assembly that the axle slides through is suppose to be tight or have some freedom to rotate a little on the axle when everything is torqued. Mine is tight and does not rotate on the axle and I did install it on the correct side of the tab and everything works.
Bone
Re: Speedometer assembly question
June 20, 2014, 02:13:35 AM »
My 98 Tourer is tight untill I loosen the fork pinch bolts.
June 20, 2014, 05:44:37 AM »
It sounds like you did it right. Its not supposed to be able to move once all is torqued down.
