February 08, 2026, 10:57:50 PM *
Author Topic: regulator for light bar  (Read 792 times)
blackvalkyrie
California
« on: June 20, 2014, 10:15:55 AM »
I bought a  accessory switch for my 97 valk ( installing engine guard lights) and I may want to install a light bar later... the web site says if I am going to draw more than 2amps I should get a relay. the vendor, cruiser customizing  does not have the relay, told me to call Big Bike Parts, their source for this switch. They too don't know much about it. I found a Rivco 30 amp electric relay on cruiser customizing, but it looks like it's more for an air horn. Does anyone know where I can pick up a relay? Will an auto parts store work? Also, where the heck does it plug in?
Thanks!
« Reply #1 on: June 20, 2014, 10:36:12 AM »
relay demystification:
trigger your relay with your accessory wire, when the relay is triggered, power flows
directly from the battery through your relay to your accessory. Triggering the relay
is a negligible draw... relays can be had the the autoparts store for $5 - $10...
« Last Edit: June 20, 2014, 10:39:46 AM by hubcapsc » Logged
blackvalkyrie
California
« Reply #2 on: June 20, 2014, 12:34:23 PM »
WOW!!!! thanks so much cooldude  do you recommend any particular brand?
« Reply #3 on: June 20, 2014, 01:17:25 PM »
I looked around at different brands at autoparts stores and on Amazon recently
when I needed a couple.
I thought this $17 solid state ceramic  Hella one looked like the bomb:
... but I ended up using el-cheapo looking ones from the autoparts store...
It seems wrong to buy something that is dirt cheap and has as
many little tiny moving parts as a mechanical relay, but they still work  Smiley
« Reply #4 on: June 20, 2014, 01:22:44 PM »
Any pair of driving lights 55W each or less is going to draw less than 10 amps, so virtually any generic off-the-rack 12V 20A-40A cube relay will be fine.  Auxiliary lights are not a mission-critical, so I wouldn't be fussy about brand name, but Bosch, Tyco, Potter & Brumfield, Siemens, Omron, and Hella all have well-known names and reputations to uphold, so I would be fine with any of them.  If you're not getting a sealed relay, be sure to put it somewhere less likely to get wet.  As for plugging it in, you can buy relays that come with a socket with pigtail wires, or you can buy terminals for your wires that fit the 1/4" tabs that come out the bottom of the relay.
Any relay that looks like this will be easy to find:
An example of a pigtail socket:
Or skip the pigtail socket and just use these on the ends of your wires to connect to the relay:
As far as "many little tiny moving parts" goes, relays are almost as simple as any electrical device can be.
blackvalkyrie
California
« Reply #5 on: June 20, 2014, 06:46:06 PM »
thanks! cooldude
blackvalkyrie
California
« Reply #6 on: June 20, 2014, 06:47:00 PM »
thanks... all you folks are the best..i appreciate it! cooldude
