February 09, 2026, 04:57:52 PM *
Author Topic: Headlight lines  (Read 1020 times)
Napa Valk
Napa
« on: June 21, 2014, 12:40:19 PM »
Hi Everyone,
I just installed a bi-zenon headlight lamp, I love it.  It is so bright I feel like it lights up at least a half mile ahead of me.  The only issue is that now I have really bright horizontal lines going across the road.  There are three or four of them and they make the light really uneven.  They are real bright and between them is darker.
Is this because of the lines on the glass, the lines on the reflector, or both?
If this is the case what do I need to get and where?
If not what, is the issue?
Doug
O-B-1
Vancouver, WA
« Reply #1 on: December 22, 2014, 02:03:05 PM »
Sounds like the bars in the lens are being projected out into your vision by teh super bright bulb.
David W. Mitchell
1999 Honda Valkyrie GL1500C
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #2 on: December 22, 2014, 06:14:02 PM »
 cooldude on what the Jedi Master stated.
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
« Reply #3 on: December 24, 2014, 10:06:22 AM »
Sounds like your focal point of your light source is very small.  A diffuser might help.  Or even moving the point source of the light around some, if you can move it out of the focal point of the reflector, to "unfocus" it some.  Using shims or spacers.  Will take some experimenting to find the optimal point.
I use a Halogen 130/90 bulb.  The 130 filiment is large, meaning only part of it is in the tight focus of the reflector.  It lights up the road CLEARLY for a measured half mile - no "bars" in the light.  No problem seeing a brown mule deer wandering onto the road for some distance.  As long as I don't look away too much, can't overdrive the light even at 80.  Though I'm pretty much never in that much of a hurry at night.
My 130/90 bulbs typically last around 3 years or so.  With every replacement the headlight needs to be re-aimed.  Indicates the filiments are not in exactly the same position with each bulb, though they all came from the same maker (and maybe lot, I bought them in a batch). I get them at Competition Accessories, http://www.compacc.com/p/kuryakyn-replacement-headlight-bulbs.  Brand is Kuryakyn.  With such powerful, long reach lights, focus precision becomes an issue.  When compared to wimpy bulbs.
« Last Edit: December 24, 2014, 10:19:06 AM by MarkT » Logged
