July 08, 2025, 05:31:12 AM
What Anti-Freeze To Use?
Topic: What Anti-Freeze To Use? (Read 1536 times)
Steve K (IA)
Cedar Rapids, Iowa
August 06, 2009, 09:15:20 AM »
I think it is time to change the anti-freeze in both bikes and can't remember what I got in the past. I know it has always been said to use silicate free coolant. What brand can I get at Walmart that will meet this requirement?
States I Have Ridden In
OverdueBill
Elkmont, Alabama
Re: What Anti-Freeze To Use?
August 06, 2009, 09:25:10 AM »
The cheaper Prestone in the yellow jug states on the label that it is silicate free. They had 4 brands when I went and this was the only one that stated it plainly.
Grandpot
Fort Mill, South Carolina
August 06, 2009, 10:10:03 AM »
"Old Yeller" (Prestone) meets the requirements.
Experience is recognizing the same mistake every time you make it.
Steve K (IA)
Cedar Rapids, Iowa
August 06, 2009, 11:12:41 AM »
Thanks for the replies. I have a partial bottle of anti-freeze in the garage from O'Reilly that say's on the front..."safe for all metals including aluminum", then I looked on the back at the ingredients and it clearly stated silicates. I know I never used that in the bikes. I'm thinking it was a Havoline brand.
Anyway, my wife thinks the fan has been coming on frequently on the '97 Std that she rides. More often than I think it should. She might be hearing things? I know the fan on the I/S doesn't come on unless I am in stop and go traffic on a hot day. I guess maybe I should take it out for an extended ride and see for myself. But it has been 3 years since I changed out the coolant, so that's on my to do list in the next few days.
Grandpot
August 06, 2009, 11:47:46 AM »
Steve:
The problem with the silicates is that they wear the seals and bearings of the water pump. That was a good catch you made by reading the label. Although it said safe for aluminum, it really wasn't safe for the Valk.
August 06, 2009, 12:34:10 PM »
One gallon of Prestone Dexcool and a gal of distilled water will make 2 gallons of coolant for both bikes. If you need anymore, just top them up with more distilled water.
=> InZane XXV
