February 08, 2026, 10:57:49 PM
installing interstate switch to standard
Topic: installing interstate switch to standard (Read 745 times)
matt
Derry New Hampshire
June 22, 2014, 08:25:38 AM »
Hello this may have been answered but I cannot find it. I am going to install right side handle bar switch from an interstate so cables come out of bottom. The questions are can I use same throttle cables or do interstate ones have same bend and is grip end same to fit in switch if cables come out a different spot? Thank you for any help with these questions. Sorry This long as I am typing brain is running. Does anyone have braided throttle cables longer than stock that would work on a standard with duece risers? If so do you have company and part #? I just feel better running cables the way they are. Thanks again
Re: installing interstate switch to standard
June 22, 2014, 08:30:36 AM »
The switch can be made with no other change required to any items such as you mention.
Attic Rat
VRCC # 1962
Tulsa, OK
June 22, 2014, 10:05:02 AM »
Standard cables are longer than the interstate other than that they are the same
matt
Derry New Hampshire
June 22, 2014, 01:40:50 PM »
Thank you not sure which way I want to go. Change switch or get longer cables
