February 09, 2026, 12:44:13 AM *
Author Topic: Front brake and Clutch master cylinders  (Read 750 times)
Westsider
Fort Worth TX.
« on: June 22, 2014, 11:46:42 AM »
Are interchangeable, correct?...(from a IS to a standard).. Won't ones from an Interstate work on a standard? Checking the parts fiche they are way different in $$. Standard ones being a lot more... My standard ones work fine but the finish on the exterior is bad. Some IS parts bikes are available and just wondering.Thanks
« Last Edit: June 22, 2014, 11:59:32 AM by Westsider » Logged
« Reply #1 on: June 22, 2014, 01:57:52 PM »
Can't tell you for sure if they are interchangeable. I own both (98 Std and a 2000 I/S) and they look the same to me¿  crazy2  Another option is to polish those reservoirs. I did that on my 98 because I was facing the same situation you are. Take care not to  scratch the plastic reservoir window.
My rides:
Westsider
Fort Worth TX.
« Reply #2 on: June 22, 2014, 02:06:27 PM »
I know right,, they look identical,, why the big diff at HDL....Hmmm. ???
My windows are pretty nasty already also.,, Ive rebuilt the carbs, brakes , insides are spick and span, , outside, not so much Grin Grin
This is the rescue scooter,  running like a pissed off hornets nest, and stops on a dime on a silver dollar, just these little details now!!
« Last Edit: June 22, 2014, 02:20:46 PM by Westsider » Logged
« Reply #3 on: June 22, 2014, 02:35:44 PM »
This isn't only part probably that Honda has that is the same physically with a different part number and price.  Look at the drive shaft for a 97 verses other years, nearly identical way different price. Also you might want to look at Partzilla.com,  they can be less expensive. FWIW
My rides:
olddog1946
Moses Lake, Wa
« Reply #4 on: June 23, 2014, 05:37:25 PM »
I don't know if they are identical or not but I am running IS calipers and master cylinder on my standard.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
