snakemeister
« on: June 27, 2014, 03:28:11 PM » |
When I apply the brakes on my 1997 Tourer it blows the fuse that controls my horn, turn signals and rear tail light. Is there any usual suspects for this?
« Reply #1 on: June 27, 2014, 03:42:18 PM » |
You probably have a short in your harness to the brake light, or on of the switches. I had a similar problem and it took me a while to find it. It was some wiring I added in the tail light that was shorting to ground. If doesn't take much, just a break in the insulation, or a wire pinched.
Also check the wiring under the rear fender, sometimes the wires aren't located properly and rub. Those are my best guesses.
« Last Edit: June 27, 2014, 03:43:55 PM by Skinhead »
Michvalk
« Reply #2 on: June 27, 2014, 03:49:38 PM » |
First place to look is the connector under the rear fender. It's easy to reach from the back
pancho
« Reply #3 on: June 27, 2014, 04:48:30 PM » |
First place to look is the connector under the rear fender. It's easy to reach from the back  Plus, if you unplug it, it isolates a lot of hardware to help isolate the problem.
« Reply #4 on: June 27, 2014, 08:20:26 PM » |
If you have a conventional tail light bulb, check it first. If one element is broken, it can short over to the other element and do what you're seeing.
rhinor61
« Reply #5 on: June 28, 2014, 11:18:02 PM » |
Blowing fuses can happen several ways...
A. +12vdc wire going to ground B. Over current draw on the circuit, the amp rating is to protect the wires and the down stream devices from catching fire.
There is no way element to element on 12vdc will ever blow a fuse, its the same 12vdc. each element is just a different resistance.
replace fuse and test each item on the circuit 1 at a time. Get you wiring schematic out and follow the wires/devices.
John
Northern California 1998 Valkyrie Tourer Black/jade VRCC #28001
mike72903
« Reply #6 on: June 29, 2014, 10:41:47 AM » |
But if the elements are shorted together they would be in parallel. Resistance's in parallel reduce total circuit resistance thus more current flow at the same voltage. Ohm's Law I=E/R
« Last Edit: June 29, 2014, 10:45:03 AM by CI_borg »
indybobm
« Reply #7 on: June 29, 2014, 03:13:58 PM » |
Never say never. It might be unlikely but not impossible. One side of the winding would be resistive, the other side is straight +12vdc to ground if the winding is shorted to the bulb case. Seen it before.
So many roads, so little time VRCC # 5258
rhinor61
« Reply #8 on: June 29, 2014, 11:45:44 PM » |
okay... maybe it could happen else where, but on a TOURER the tail light and brake light is on the SAME 15amp fuse, both loads are happening ALL the time.
and I dont blow a fuse when I apply my brakes.
John
cokebottle10
Green and Silver 99 I/S
Fletcher NC
« Reply #9 on: June 30, 2014, 05:38:57 AM » |
An old trick is to solder a single element 12 volt light bulb across a blown fuse (1156?). The voltage will pass through the element to the wires. Remove the loads (Lights) downstream. Now you and can move the wiring harness around and if it shorts it will light the light. The light acts as a fuse.
Thanks, David in Fletcher NC.
