November 19, 2025, 07:14:16 PM
4way Flashers
Topic: 4way Flashers (Read 2015 times)
desanshe
White Rock, British Columbia, Canada
4way Flashers
August 06, 2009, 08:56:55 PM »
Good Evening All:
Again, I request information from you guys.
Our motorcycle club does a great deal of escorting for bicycle races and we are supposed to have "4way Flashers"and my 99 Valk IS does not have them.
It seems to me that I have seen a kit for sale at one time or another. Can someone please help me out.
Thanking you all in advance
Roger
woody
Australia
Re: 4way Flashers
August 06, 2009, 09:00:33 PM »
Try this
http://www.rattlebars.com/valkfaq/circuits.html
have fun
Thunderbolt
Worthington Springs FL.
Use the 4 ways for $5 diagram
August 07, 2009, 05:05:06 AM »
under the right side cover the wiring that heads toward the rear of the bike has in it an orange and a blue wire. These are the turn signal wires. This is where you want to attach the 4 way wiring. Just go to your auto parts store and get a 2 prong 12V flasher and a small switch and a fuse. Wire it like the diagram. Works like a charm. I used a small switch from Radio shack and mounted it in the center panel near the key that unlocks the seat, nearer the right side. When you turn the switch on, it puts 12V from the battery through the fuse,through the flasher to both turn signals.
PAVALKER
Pittsburgh, Pa
Re: 4way Flashers
August 07, 2009, 07:29:28 AM »
Quote from: woody on August 06, 2009, 09:00:33 PM
Try this
have fun
I did the Rattlebars mod and applied the power to the switch in the Center lead, that way I can use the switch for 4 ways in one position, LEDs in the other position and of course OFF in the center position. Can't have LED's and flashers on at the same time obviously.
John
mooserider
Blue Knights TX6, Ride with Pride
La Porte, Tx
Re: 4way Flashers
August 07, 2009, 08:53:11 PM »
I installed the 4 way flashers on my tourer tonight, I'm very happy with it. I installed my switch on the center panel next to the key hole. total cost maybe 5 dollars. I used the rattler brothers instructions.
Ride with Pride
Re: 4way Flashers
August 07, 2009, 10:16:52 PM »
Kisan signal minder has 4 ways parade flash and cancels turn signals plus much more.If you have leds for the turn signals you don't need a extra module to get them to flash.
https://www.kisantech.com/index.php?cat_id=4
Last Edit: August 07, 2009, 10:19:41 PM by Robert
=> InZane XXV
