February 09, 2026, 12:57:53 AM *
Author Topic: # 2 carb.  (Read 981 times)
bogator
IN GOD WE TRUST------KK4KSN-------
Valley,Al
« on: July 02, 2014, 11:58:44 AM »
OK, I need a little help on this, the steeler is cleaning my carb's and the mech. took the air needle out of the # 2 carb ---and the very end of the needle broke off, can not get it out. even soakin it ,BUT , I have it here at the house and ben messing with it, just to see what I could do to get it out ====to small for a dremel to drill out---SO--here is what I would like to know----if I leave it in and use the same jet for the adjustment ---WILL IT WORK???????   I can not afford a new carb, 460.00 ---tell me what you think?? GOD BLESS. John mite know??? OH, a new needle won't go in place either. THANKS---it don't effect the air goin in, I checked.
Crackerborn
SE Wisconsin
« Reply #1 on: July 02, 2014, 12:28:39 PM »
If the stealer broke a pilot jet off, it seems to me it should be the dealers responsibity to correct the problem. If the carb bank is off the bike, remove the float/sediment bowl cover and use compressed air to blow the broken tip out. Other than gas treatment, I am not sure how a stealer would clean the carbs on the Girl.
97 Valkyrie Tour
99 Valkyrie Interstate
rugguy
2000 Valk I/S
Atlanta, GA
« Reply #2 on: July 02, 2014, 04:21:21 PM »
+1 on what Crackerborn said...
I hate sand....sand SUCKS!
I wear a helmet....."I'd rather have brains in my head than wind in my hair"
1999 Valk I/S
2000 Valk I/S
2001 BMW K1200 LTE (sold)
2002 FLHRSEI (for sale)
2006 FLHCTUI (sold)
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #3 on: July 02, 2014, 05:07:31 PM »
Send it to me and I will see if I can fix it or if I can't, I may have a used carb to replace it. I have some single carbs laying around off a valkyrie
« Last Edit: July 02, 2014, 05:10:03 PM by Attic Rat » Logged
F6BANGER
Albuquerque NM
« Reply #4 on: July 02, 2014, 06:15:49 PM »
ATTIC RAT....You Da Man!!!
bogator
Valley,Al
« Reply #5 on: July 03, 2014, 01:41:11 AM »
First of all, a big thank you to Attic Rat, but I think I got it out, my friend Troy is coming over this AM to look at it--he said- and I think that the brass part that I'm looking at is the base for the needle to sit on, cause the aluminum is to soft for it to sit on, I will let you know after a while, and if I have to I'll send it to Attic Rat, that would save me some ----big bucks---to me right now!! thank all of you that replied to the post. ------GOD BLESS----
bogator
Valley,Al
« Reply #6 on: July 03, 2014, 07:03:12 AM »
Attic Rat, Troy just left,, and --yes --the brass is broke off in the carb.,  if you will send me your address I will get it on the way to you -----jamesclay352@gmail.com------phone # 334 756- 3067--
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #7 on: July 03, 2014, 07:42:38 AM »
I got your info and I do have a #2 carb so send the carb up and I will either fix it or send you another one.
bogator
Valley,Al
« Reply #8 on: July 04, 2014, 02:43:26 AM »
Attic Rat, the carb. is on the way, it will be there Monday, Thank you.
