November 26, 2025, 03:28:50 AM *
Author Topic: led lites on 1500  (Read 1248 times)
oldfartfrankie
Unicoi, Tn.
« on: July 05, 2014, 03:15:59 PM »
Help!
Got a hoppy 46365 converter for my trailer, but will I still need a load eq. and what is recommended?
I also want to convert my 98 CT w/ Cal. Side Car to led. This kit has 85 Aspencade
TRUNK lites on the rear.Any help out there? tickedoff crazy2
  old fart frankie!
twdurdentwd
Sebastian, Florida
« Reply #1 on: July 05, 2014, 03:20:27 PM »
However you decide to do it, make sure you put a relay in the circuit ... To avoid issues with the starter button
00' Valk tourer - 6-6, trigger wheel
00' Valk std - complete build
00' I/S salvaged.. Transplant to std
BonS
Blue Springs, MO
« Reply #2 on: July 05, 2014, 03:52:13 PM »
You don't need load equalizers if the only change you make is adding LED lights to the Hoppy 46365 trailer light outputs. If you change the bike turn signals to LED then you either need equalizers or install a blinker relay designed for LED's such as the Kisan SignalMinder which is a good bit more expensive.
If you're keeping your bike's incandescent bulbs but simply adding LED's to the side car then you don't need load equalizers because the existing bike bulbs will do the job.
oldfartfrankie
Unicoi, Tn.
« Reply #3 on: July 06, 2014, 10:56:23 AM »
Bons,
The trike kit is from Cal Side Car Co. in Virginia 2funny. Mustang8 bolt rear, little trunk in back,
lites about 12" off the ground! My intention is to change ALL the bike bulbs to LED ( even in the
head lite bucket w/ diode). Since this is my first Valk, I could use all the input fromyoufolkss I can get!
Thanks Again!
Frankie
« Reply #4 on: July 06, 2014, 07:41:02 PM »
I have mostly leds with the exception of the headlight and I do have the Kisen signal minder with no other load equalizers. BonS gave it to you straight, led light will be no problem and will actually be much better as wont pull so much power and will be brighter.
oldfartfrankie
Unicoi, Tn.
« Reply #5 on: July 18, 2014, 01:45:41 PM »
Thanks to ALL!
Installed Hoppy converter and it works great! Have a little flicker in the lites. I'm going with the Kinzer Signal Minder SM 3- all but the headlite. If I still have the flicker I'll try addding a load eq. Grin Grin
      Frankie!
BonS
Blue Springs, MO
« Reply #6 on: July 18, 2014, 03:30:27 PM »
Which Hopkins converter did you use? I had flicker when I had a Blinker Buddy and the Hopkins 46255 but it went away with the 46365. Also, be sure to bag the Kisan Signal Minder to keep it dry. It's not waterproof and water will get into it. Don't ask.
oldfartfrankie
Unicoi, Tn.
« Reply #7 on: July 23, 2014, 04:38:51 PM »
BonS,
Used a 46365 Hoppy as U advised, thank u very much!  When the turn signal flashes on either side,
I get a fluctuation in the rest of my lites. Had that since I bought the ole girl. Hope to install the
SM 3 signal minder & LED's next week. We'll see what happens!
 Frankie Grin
« Reply #8 on: July 24, 2014, 09:52:47 AM »
BTW recent versions of the Kisan SM has several useful add'l functions - hazard flashers, true cancelling with a small mod to the switch, running lights, brake flash, selectable time-outs (this one not new) and they incorporated my timer-defeat invention by connecting to the brake line a dozen years ago.  I'd replace my old one but I've added all these fn's already via other mods except the true cancelling.  I have mixed LED's and tungsten and have added other loads and the Kisan just handles it.  Recently I made a special Highlighter for myself with 54 extra-bright LED's (instead of 25) that is wired as run, brake and turn.  Kisan didn't care about the extra load - which granted isn't much.  I'm not offering this Highlighter for sale as it's more wiring than the typical user would want to do - and it takes me a lot of time to make it as it's handmade - would make it's price too high - so if I offered it, the Chinese would rip it off and I can't compete with their 50¢ / hr labor.  I wired this into the circuit I made for run/brake/turn on the rear markers, detailed at http://www.horseapple.com/Valkyrie/Tech_Tips/VTX_signals/vtx_signals.html  There is only one 2-conductor wire to the Highlighter.
SuperHighlighter for Valkyriepowered by Aeva
« Last Edit: September 17, 2014, 04:20:44 PM by MarkT » Logged
GeoffreyB
Katy, Texas
« Reply #9 on: July 24, 2014, 02:54:06 PM »
Not to hijack this thread - but MARK-  That is VERY cool.  I'm sure it was a ton of work.
