February 09, 2026, 02:57:16 AM *
Author Topic: Dipstick  (Read 2218 times)
Louis Durocher
'99 Interstate
Montreal,Canada
« on: July 07, 2014, 06:00:54 PM »
Does anybody know where i can find a oil dipstick with integrated temperature gauge?
Have a safe ride
« Reply #1 on: July 07, 2014, 06:22:09 PM »
https://www.teltru.com/s-95-honda-motorcycles.aspx
HDL may sell them... if you can find anything on that site.
I believe someone put one in our classifieds in the last week.
FYI, the larger face gauge will just touch the right side Kuryakyn trans cover.  I have one of each, large and small face.  What I did was cut a sliver of elect tape and lay it across the 220* line; I have trouble seeing the temp numbers while riding, but a glance down tells me I am below 220, I'm good to go.
Keep your OE stick for checking oil.
Challenger
Posts: leet
« Reply #2 on: July 07, 2014, 06:24:03 PM »
Here is one, Cashy, but they work well.   http://www.madcorider.com/tempstick.html
RONNIEB
NEWCASTLE, OKLAHOMA
« Reply #3 on: July 10, 2014, 07:20:24 PM »
Have the teltru 1 7/8 inch dial on both my gurls, work great cooldude
1999black standard; 2000 black tourer; 1999 red/black interstate
Bugslayer
Lubbock, Texas
« Reply #4 on: July 10, 2014, 08:40:59 PM »
I also have the TelTru..... I can check my temp on the fly...... Works great!
eight_pockets
« Reply #5 on: July 12, 2014, 05:36:42 AM »
My Valkyrie came with one installed.  I love it. It looks so good I thought it was stock.
I do have a problem,. though: I'm not sure where the oil level should stop on the stick; the vapor blasted bottom part or the upper groove. That groove looks too far away.
Bone
« Reply #6 on: July 12, 2014, 05:42:30 AM »
eight_pockets
Can you borrow one from another Valkyrie and match them up to mark yours ?
Or do an oil change make sure the filter is filled by starting then check to see where the level is on your dipstick and mark.
eight_pockets
« Reply #7 on: July 14, 2014, 06:41:26 AM »
Bone,
I don't know any other Valkyrie owners, but that is a good idea.  We also have a Honda shop near by; I'll go ask them too.
Bone
« Reply #8 on: July 14, 2014, 06:56:13 AM »
Hey I will go out and measure the one in my 98 Tourer.
Paxton
So Cal
« Reply #9 on: July 14, 2014, 06:59:03 AM »
Mine came with it and it looks great. However, I forget that it's there and "find it" every time I wash the gurl!  Embarrassed Sad
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
Bone
« Reply #10 on: July 14, 2014, 07:47:56 AM »
eight_pockets if you still need the measurement mine is 8.5 inches
from the threads to the middle of the 2 marks on the stick.
Owners manual says that is the full level.
Paxton
So Cal
« Reply #11 on: July 14, 2014, 08:10:10 AM »
You're supposed to check the oil with the stick not screwed in. Bike must be standing up straight on a flat surface. Wink
A wheel chuck would be helpful and safer to keep her standing straight. Roll Eyes
If cold, start the bike and let it idle until normal operating heat-range is achieved.  Smiley
Better yet, take a short ride around the block. Upon return, shut her off and wait 3 minutes before checking the oil. cooldude
J. Paxton Gomez
So Cal... 91205
eight_pockets
« Reply #12 on: July 20, 2014, 09:48:41 PM »
Thanks so much, Bone!
For others with the same issue, bone's numbers put the oil level in the middle of the grit blasted area of the thermometer stick.
Bone
« Reply #13 on: July 21, 2014, 05:57:31 AM »
Glad it helped you. If you didn't get a owners handbook with the bike Paxton posted the correct procedure for checking the oil don't screw in the dipstick to check the level.
« Reply #14 on: July 21, 2014, 06:48:31 AM »
I take out 4 quarts, add a new filter, and put 4 quarts in every 5 to 6 thousand miles, don't hardly ever check the level, it always dispenses 4 quarts when I change.  Hoser   cooldude
BudMan
"Two's in."
Tecumseh OK
« Reply #15 on: July 22, 2014, 06:46:34 PM »
+1 cooldude
Buddy
Tecumseh OK
MOOT# 263
VRCC # 30158
1948 EL Harley
2013 F6B Delux
