November 19, 2025, 07:14:19 PM *
Author Topic: I/S fairing adjustment  (Read 1753 times)
Ferris Leets
Catskill Mountains, N.Y.
« on: August 07, 2009, 11:57:33 AM »
Is there any?  I thought somewhere in the repair manual I saw something about an adjustment screw but now I can not find it.
Oyeaa
« Reply #1 on: August 07, 2009, 12:41:22 PM »
You can adjust the headlight aim, but the fairing itself is rigidly mounted.  You would have to do some work (modification) to adjust it
Ferris Leets
« Reply #2 on: August 07, 2009, 12:48:19 PM »
Ahaa, a challange to my fabrication and imagination.  Will post the follow up.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #3 on: August 08, 2009, 08:56:38 AM »
What kind of adjustment do you need to make?  Is your ride a trike?
States I Have Ridden In
Ferris Leets
« Reply #4 on: August 08, 2009, 01:46:58 PM »
NO trike, I was hoping to adjust the windshield down about an inch.  Probably end up cutting it.
Oyeaa
« Reply #5 on: August 09, 2009, 07:22:16 AM »
I highly recommend cutting W/S it will be much easier than modifying the mount for the entire fairing.  A lot of people cut the W/S or just purchase a shorter one.  There are several W/S options out there.
http://www.motorcyclecruiser.com/tech/remove_windshield/index.html
When I cut mine I follow a similar process as outlined in the article above except.  First I protect the W/S with the blue painters masking tape because it comes off easily and leaves no residue to clean off and then I cover the blue masking tape with several layers of duct tape because it is much more durable.  Then when I am done cutting and sanding with a power sander I carefully heat the edge with a torch to make look like a factory cut, be careful though a touch of heat to the surface will cause it to bubble and there is no way to fix the bubbles.
