March 15, 2026, 09:23:13 AM *
Author Topic: Hey Eddie....  (Read 1547 times)
« on: July 08, 2014, 06:29:45 PM »
In your stash of Valkyrie stuff would you happen to have the right hand controls. I found the problem with the 1200 and why the start button didn't work; a broken wire right at the push button. The place that I'd need to solder it to is about the size of a pinhead and I don't have the tool to do that, needs something used on PC Boards. Since I plan to use Valkrie controls and m/c on both sides, I don't plan to but another 1200 right side control, I'll opt for a Valk set...already have the left side, two in fact; one for an I/S.
Tropic traveler
Silver Springs, Florida
« Reply #1 on: July 08, 2014, 06:51:06 PM »
I think I have a right side used. I replaced it with a new one just because I wanted no starter button issues on a long trip.
You are welcome to it.
'13 F6B red for Kim
« Reply #2 on: July 08, 2014, 07:02:56 PM »
I can use it, I'll clean up the starter button and install a relay in the headlight to cut out the major amp draw. No hurry, I'll hook up with you on a ride somewhere. I have plenty of work left to do now that I know that circuit works. Thinking about cutting those wires from the start button and put a temp push button somewhere until it's time to actually get serious about replacing it.
