sawdustar
« on: July 09, 2014, 01:45:16 PM » |
I noticed that while riding in the colder temps in the winter, the starter push button would stick causing the starter to run even after the engine started running. I had to use my pocket knife to pull the button out so the starter would shut off. In the warmer temps, like now, it doesn't stick at all.
What needs tweaking so this doesn't happen again during the winter months.??
Thank You, Dennis
nogrey
Nampa, Idaho
« Reply #1 on: July 09, 2014, 01:52:04 PM » |
It's probably old lubricant getting thick and restraining the button. If it were me, I would disassemble the switch housing, clean out with an electrical contact cleaner or the like, and re-assemble with a nice coat of silicone spray or other light lubricant on it. You could try just shooting some silicone up in the switch area. It's not a conductor so can't harm anything, but probably will be a temporary fix at best. Good luck.
« Reply #2 on: July 09, 2014, 05:51:33 PM » |
Go to Radio Shack or similar and get some Electroic Parts Cleaner, not a lube, but the cleaner. Spray in there while working the button. Then sprits in the lube spray, get rid of the old stuff first.
« Reply #3 on: July 10, 2014, 05:15:46 AM » |
That's what you do on the road for an emergency "fix". Do it right, take the switch out, clean the inside of the housing, clean the switch, make sure you don't lose the spring, insure the contacts move freely on the spring, put a light coat of dialectic grease on the moving parts and put it back together........Its not that hard
sawdustar
« Reply #4 on: July 10, 2014, 08:50:00 AM » |
OK...I'll get to this fairly soon. Thanks for the tips and advice.
Thank You, Dennis
Daniel Meyer
The State of confusion.
« Reply #5 on: July 10, 2014, 08:57:49 AM » |
CUAgain, Daniel Meyer
Bronxboy
« Reply #6 on: July 10, 2014, 12:58:20 PM » |
I am having an intermitting problem with mine. Sometimes it starts up with no issues and some times I hit the button and nothing. I opened it up and cleaned it out with electronic spray cleaner but it still does it. I went to dealer and they don't just sell the switch. I had to buy the whole assembly, wire and all. He said it was plug and play? will see. I had to order it for $97.00, has anyone rewired one of these before? Is it easy or am I looking at hard labor...lol I have my entire bike ripped apart anyway because I am doing front and rear tires and new fork springs, new shocks, antifreeze, brakes, Powder coating wheels as well. So no hurry on the switch.
« Reply #7 on: July 10, 2014, 01:11:16 PM » |
I am having an intermitting problem with mine. Sometimes it starts up with no issues and some times I hit the button and nothing. I opened it up and cleaned it out with electronic spray cleaner but it still does it. I went to dealer and they don't just sell the switch. I had to buy the whole assembly, wire and all. He said it was plug and play? will see. I had to order it for $97.00, has anyone rewired one of these before? Is it easy or am I looking at hard labor...lol I have my entire bike ripped apart anyway because I am doing front and rear tires and new fork springs, new shocks, antifreeze, brakes, Powder coating wheels as well. So no hurry on the switch.  You can clean those parts all day long. But, if the contacts don't move freely on the little spring even your brand new one can have problems. My new one went a month or so before it quit. Yep, I had to get that contact thingy freed up
nogrey
Nampa, Idaho
« Reply #8 on: July 10, 2014, 06:05:52 PM » |
I am having an intermitting problem with mine. Sometimes it starts up with no issues and some times I hit the button and nothing. I opened it up and cleaned it out with electronic spray cleaner but it still does it. I went to dealer and they don't just sell the switch. I had to buy the whole assembly, wire and all. He said it was plug and play? will see. I had to order it for $97.00, has anyone rewired one of these before? Is it easy or am I looking at hard labor...lol I have my entire bike ripped apart anyway because I am doing front and rear tires and new fork springs, new shocks, antifreeze, brakes, Powder coating wheels as well. So no hurry on the switch.  It really isn't a bad job at all. Just take your time and pay attention to how you take things apart. It's not a watch, and nothing's going to come flying out when you open it up. If you want to send me the old one, I'll repair it for you and send it back just for postage.
8Track
« Reply #9 on: July 10, 2014, 08:32:36 PM » |
Hey Nogrey,
Are they all your Valkyries in the photo?
Cheers,
Mark
Bronxboy
« Reply #10 on: July 11, 2014, 11:21:14 AM » |
I am having an intermitting problem with mine. Sometimes it starts up with no issues and some times I hit the button and nothing. I opened it up and cleaned it out with electronic spray cleaner but it still does it. I went to dealer and they don't just sell the switch. I had to buy the whole assembly, wire and all. He said it was plug and play? will see. I had to order it for $97.00, has anyone rewired one of these before? Is it easy or am I looking at hard labor...lol I have my entire bike ripped apart anyway because I am doing front and rear tires and new fork springs, new shocks, antifreeze, brakes, Powder coating wheels as well. So no hurry on the switch.  It really isn't a bad job at all. Just take your time and pay attention to how you take things apart. It's not a watch, and nothing's going to come flying out when you open it up. If you want to send me the old one, I'll repair it for you and send it back just for postage. Thanks for the offer, but I will put the new one in and tinker with the old one. That is the only way to learn, This bike is in pieces now and I cant wait to get it all together again.
twdurdentwd
« Reply #11 on: July 11, 2014, 11:23:35 AM » |
I am having an intermitting problem with mine. Sometimes it starts up with no issues and some times I hit the button and nothing. I opened it up and cleaned it out with electronic spray cleaner but it still does it. I went to dealer and they don't just sell the switch. I had to buy the whole assembly, wire and all. He said it was plug and play? will see. I had to order it for $97.00, has anyone rewired one of these before? Is it easy or am I looking at hard labor...lol I have my entire bike ripped apart anyway because I am doing front and rear tires and new fork springs, new shocks, antifreeze, brakes, Powder coating wheels as well. So no hurry on the switch.  Get yourself a dremel. Then be careful with it...
00' Valk tourer - 6-6, trigger wheel 00' Valk std - complete build 00' I/S salvaged.. Transplant to std
