February 09, 2026, 02:56:29 AM *
Author Topic: Headlights question  (Read 1164 times)
Loki
Katy, Texas
« on: July 11, 2014, 07:49:07 AM »
I've searched the forum and the service manual and can't seem to find the answer to this question.
When using lowbeam are both headlights on?  I just noticed the other day that on low beam only my right headlight is lit.
Thanks!
Marc
Marc
'00 Valkyrie Interstate - Loki
'85 V65 Magna - Big Bird
Rio Wil
« Reply #1 on: July 11, 2014, 08:00:36 AM »
Left has a burned out low beam filament.....
rhinor61
Northern California
« Reply #2 on: July 11, 2014, 08:03:06 AM »
When you say both... Do you have an Interstate model Valkyrie?
If so YES, both head right and left side are on in LOW or on in HIGH.
To confirm this look at the electrical schematic, the Interstate headlights are on Relay and split power to each headlamp at the connect inside the fairing.
http://www.rattlebars.com/valkfaq/schematics/rpage04i.html
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
Loki
Katy, Texas
« Reply #3 on: July 11, 2014, 08:06:17 AM »
Thanks guys, yes, it's an Interstate so apparently both should be on.  I thought as much but was second guessing myself.  Looks like it's time for a bulb change.
Appreciate the feedback!
Marc
Marc
« Reply #4 on: July 11, 2014, 08:49:53 AM »
Get two and change them both.
The other bulb is sure to go soon, at least that's my experience.
Also, I'd suggest to stay away from high wattage bulbs.  The
extra heat from them can cause a problem with the headlight case.
Loki
Katy, Texas
« Reply #5 on: July 11, 2014, 08:56:33 AM »
Going with the standard OEM replacement bulbs Ricky.  45/45 I believe.  I think I might also have a couple of spares socked away already.  Just have to find where I socked them!
Marc
Marc
BigMac (SoCal)
Moreno Valley, California
« Reply #6 on: July 11, 2014, 03:53:40 PM »
I have had no problem with the 50/60 bulbs and have used them for 10 years. I also run high beams all the time during the day.
Dave
« Reply #7 on: July 11, 2014, 04:06:33 PM »
Dave
     cooldude cooldude RIDE SAFE.
Rio Wil
« Reply #8 on: July 11, 2014, 04:12:34 PM »
If you are changing bulbs, I highly recommend you go to the Ho/Lo beam 60/55 W bulbs......they will give a significantly more amount of light at night without washing out hwy/street signs due to too much reflectivity on the signs......well worth it..if you don't drive at night....then any will do.
« Reply #9 on: July 12, 2014, 01:34:02 PM »
Buy the stock car bulb, I forget it that is the H3 or H4, not the OEM. Honda wants too much for them. You break off the two lower tabs.
Some sell the ring that you are supposed to mount over top of the bulb to hold it down, but most don't bother and have reported no problems.
Also, get someone with small hands, wife/child, and have them fit it in. Don't touch the glass. I clean it off with alcohol first, and then use gloves to I don't leave oil behind on the glass.
How did I know my one light was also burnt out?
« Last Edit: July 12, 2014, 10:19:25 PM by gordonv » Logged
Bone
« Reply #10 on: July 12, 2014, 02:06:17 PM »
I don't ride after dark unless I'm traveling I live in a area with very big deer population.
Read an article about headlight bulbs losing brightness as they age. Figured my 98 Valkyrie had it's factory bulb so I changed it and what an improvement. I used a Philips brand 9003/H4. The back of the card has it at 67/60W. Made me want to ride at night.
Didn't go far the deer looked bigger and closer Sad
Crackerborn
SE Wisconsin
« Reply #11 on: July 12, 2014, 06:34:51 PM »
The deer on the road are a PITA and should be served with gravy and potatoes. The dear at home must be listened to. Put relays in and run any H4 wattage bulb you are happy with. I added low height running lights that outshine any headlights but still tuck in behind cages when traveling at night hoping they will act as deer intermediaries.
97 Valkyrie Tour
99 Valkyrie Interstate
