February 09, 2026, 02:55:11 AM *
Author Topic: Leaky radiator cap  (Read 973 times)
signart
Crossville, Tennessee
« on: July 11, 2014, 10:16:50 AM »
Got a friend in a nearby town, has an Interstate and is suffering a radiator cap leak. He just ordered oem cap and replaced it, but claims it is loose and won't seal. I checked mine and it takes quite an effort to press down and turn to lock, in no way could mine be considered loose. Haven't had a chance to check his yet, but does anyone else have any ideas what could be causing this?
F6Dave
« Reply #1 on: July 11, 2014, 10:25:12 AM »
Try bending the tabs on the cap very slightly.  My Interstate did that.  I placed the cap on a rag on the workbench, then tapped each tab a bit with a hammer and wooden dowel.  It fit tighter and stopped the leak.
signart
« Reply #2 on: July 11, 2014, 11:51:16 AM »
I'll let him know, but I think he has tried that with his old cap. He said the new cap is worse than the old one after tinkering.
« Reply #3 on: July 11, 2014, 01:15:55 PM »
It can be either the tabs on the cap or the tabs on the radiator neck need tweaked.... carefully.
Also, the set screw on the Show Chrome cap cover can create a leak if too tight.
signart
« Reply #4 on: July 11, 2014, 05:31:15 PM »
Yeah, I'll probably have to ride down and take a look. Sounds like it's got to be the lip on the radiator fill since the new oem cap is not sealing. Thanks
drpete65
Lincoln, NE
« Reply #5 on: July 21, 2014, 06:50:41 AM »
Had the same prob, bending the tabs, nor a new cap helped. The dealer told me I needed a new radiator. I took it to a radiator shop. They filed the fill neck and put a bigger gasket in the cap. 40 bucks and done!!!!
« Reply #6 on: July 21, 2014, 07:08:16 AM »
When ever you have a leaky radiator cap, one of
the first things to do is to check the coolant
recovery line for blockage. This can be the
cause of coolant leaking from the cap since
this function of the cap is not a pressure
sealed area but rather only sealed to allow
for capture and recovery of the coolant
during times of heating and cooling of the
radiator.
signart
« Reply #7 on: July 21, 2014, 08:36:03 AM »
Good point.
