February 09, 2026, 02:57:18 AM *
Author Topic: Brass Inserts on an I/S  (Read 1715 times)
« on: July 15, 2014, 07:44:27 PM »
that accept the screws that hold the speakers into the fairing. I've looked at H D L and another fiche AND I was at my dealer and-NO JOY. Do any of are members here have a part number or something else that can be used?? Either I'm entering stuff wrong in my search parameter or hell-I don't know so thought I'd query this storehouse of knowledge available here.  cooldude As always-T I A for any and all assistance. RIDE SAFE./
Punisher
No, not vengenance. Punishment.
« Reply #1 on: July 15, 2014, 07:54:18 PM »
Here ya go
90316-MJ1-000
http://www.partzilla.com/parts/detail/honda/HP-90316-MJ1-000.html
« Last Edit: July 15, 2014, 07:58:41 PM by Punisher » Logged
BonS
Blue Springs, MO
« Reply #2 on: July 15, 2014, 07:56:38 PM »
I don't know the size you need but these metric brass threaded inserts at MSCdirect look like a good place to start. 25 in a pack.
Kind of a long link: http://www.mscdirect.com/product/details/93441996?src=pla&008=-99&pcrid=15557577904&007=Search&006=15557577904&005=21882504424&004=4409695744&002=2167139&mkwid=sJXegN7a0|dc&cid=PLA-Google-PLA+-+Test_sJXegN7a0_PLA__15557577904_c_S&026=-99&025=c&item=93441996
« Reply #3 on: July 16, 2014, 08:58:05 AM »
Those are not at all like the Honda OEM part.
The Honda piece is a two part assembly.
The inner piece when screwing in the bolt, pushes and expands
the outer sleeve (the threaded piece) to grab a better
bite into the plastic hole.
When reusing the OEM part you should first push the inner
piece back to it's original position within the sleeve to allow
the OD to be reduced and then glue it in.
When you insert the threaded bolt it will push the insert
and expand the legs of the sleeve to increase the hold of the
assembly.  Naturally an antiseize is highly recommended
when assembly to facilitate removal when necessary.
Six-Cylinder Hooligan
« Reply #4 on: July 16, 2014, 02:32:21 PM »
Not wanting to hijack but am wondering how the heck you got those screws out in the first place... Mine just turn but never loosen!  tickedoff
« Reply #5 on: July 16, 2014, 03:14:20 PM »
While turning, place a putty knife between the inner and outer fairing, applying outward pressure to allow the screw to come out of the insert.
If it doesn't come out, then the whole assembly will need to be removed (pull) instead.
Pepmyster
Go Bonzo, Go!!!!
Mascouche, Quebec, Canada
« Reply #6 on: July 17, 2014, 05:58:45 PM »
I just tried un-screwing mine and they spin too! tickedoff tickedoff tickedoff tickedoff
Now this is getting interesting........
NITRO
Eau Claire, WI
« Reply #7 on: July 17, 2014, 06:32:50 PM »
You'll have to pull the whole thing out and glue the insert in as described above. To avoid this problem,I used jb weld on the inserts and make sure I take the fairing off once a year. Oh, and never seize on the screws helps too.
When in doubt, ride.
« Reply #8 on: July 18, 2014, 05:00:23 AM »
Been there! NITRO has the answer for the fix IMO.  cooldude  Keep the JB Weld out of the threads
My rides:
Blackduck
West Australia
« Reply #9 on: July 18, 2014, 05:51:12 AM »
You should be able to find similar State side.
Either the Aluminium,rubber or pre bulbed would be good options.
You do not need the custom tools to set these, just a bolt and spacer set up to pull and expand the insert.
I have used the stainless ones with a homemade tool
http://profast.com.au/product-category/nut-inserts/
Cheers Steve
« Reply #10 on: July 18, 2014, 09:15:03 AM »
O2S.  I have a couple of extras ifn ya need them.  PM me your address and I will mail them to you...
Hay  Cool
« Reply #11 on: July 18, 2014, 04:50:49 PM »
Preciate it Jimmy but on my ride today I stopped at the dealer and ordered a couple already. The part # Punisher gave me is a good one!!  cooldude Yet another reason I truly love this board and the folks that populate it.  coolsmiley Okey Dokey-back to our regular scheduled programming.  Roll Eyes MIGHT have had one icy cold adult beverage too many---NAAH!!  2funny RIDE SAFE.
« Reply #12 on: July 20, 2014, 08:50:48 AM »
Thanks for the reply!  cooldude
