February 10, 2026, 07:46:21 AM *
Author Topic: How the heck do ya get to the Final Drive Oil Filler Nut?  (Read 3257 times)
Kunkies
Charlotte, NC
« on: July 21, 2014, 03:58:28 AM »
I have a 2000 GL15000CT.  Started draining the final drive oil on Saturday and had a heck of a time getting to the level check/filler nut/washer.  Anyone have some advice, special tool, take off the exhaust?  I ended up using a straw, holding my finger at the bottom of the drain hole and squeezing 5.1oz that way!  Ugh.
p.s.  I have a tourer so hard bags are involved yet they don't seem to get in the way.
« Reply #1 on: July 21, 2014, 04:10:41 AM »
I only change the oil when the final drive is off the bike (tire changes/spline lube)
« Reply #2 on: July 21, 2014, 05:34:12 AM »
Get a long piece of clear tubing at the local harware and attach one end to the hypoid lube bottle and put the other end in the fill hole. It would be a lot simpler for two people to carry off the task.  Also, as Chris points out planning makes life a lot easier. FWIW ???
My rides:
« Reply #3 on: July 21, 2014, 08:10:10 AM »
If you're having trouble changing that oil while the bike is all in one piece, then you could fill it thru the vent. The vent is just pressed/pushed in. You'll just have to make sure all the old oil is out and measure 5.1 ounces before dumping it in. Some fellas have broken the vent trying to get it out, its kinda fragile.
« Reply #4 on: July 21, 2014, 10:08:09 AM »
 crazy2 Don't do this  crazy2
« Reply #5 on: July 21, 2014, 10:55:29 AM »
I don't really recommend this either, but, I don't have a problem with filling it. But, I don't see an issue with this as long as one is careful. Just another way to milk this cow if necessary.
nogrey
Nampa, Idaho
« Reply #6 on: July 21, 2014, 10:59:04 AM »
I'm no expert on this, but I've read post after post where guys have destroyed their vent trying to get it off. I've fiddled with it and I've not seen any clear cut way to remove the vent to gain access from the top. If someone out there has a sure fire way to get the vent off, please share!
« Reply #7 on: July 21, 2014, 11:17:11 AM »
Don't attempt to take off the vent! I've filled mine on the bike and off. It's a lot easier off, but if you want to do it on. I use a funnel and put clear tubing on the neck of it. I don't measure, just fill till it starts to flow back out. Kind of messy but it works.
BradValk48237
Oak Park, MI
« Reply #8 on: July 21, 2014, 11:25:57 AM »
Tubing... have been doing it for years....81 CB 900, 85 Wing, and now 00' Valk......
B
Savago
Brentwood - CA
« Reply #9 on: July 21, 2014, 12:56:46 PM »
Dear Friends
I *wish* this thread was started 3 days ago (as I've flushed the final drive oil this last Saturday)... In my I/S, the filler cap was screwed so hard that there was no way to get it free without full access to it (I tried twice and was starting to damage the cap).
My solution was to remove the exhaust pipe (how painful those 6 screws in the engine block are to access!) and next have free access to it. One advantage though, was that I had enough space to use the torch wrench and set the right torque on both screws (the filler and the drain, 12Nm and 20Nm respectively).
Best regards
Adenilson
« Last Edit: July 21, 2014, 01:50:48 PM by Savago » Logged
Kunkies
Charlotte, NC
« Reply #10 on: July 21, 2014, 02:10:28 PM »
Thanks all.
Savago; that is exactly what I was trying to avoid (removing the exhaust).  Based upon what I've read here, I would never remove the vent cap either.
« Reply #11 on: July 21, 2014, 02:24:53 PM »
Did mine yesterday. I just jacked the bike up enough to take the weight off the suspension and got to it with a box end wrench. Used the tubing to fill. I also had the bag off. You could loosen the 2 acorn nuts at the back of the exhaust if you have fat fingers.
« Reply #12 on: July 21, 2014, 02:25:24 PM »
meathead.......to do the fill till overflow method you need to have the bike perfectly vertical.  If its leaning a bit that will affect the oil volume.  Easier way if you must fill it on the bike is to do it just how you said but ON THE SIDE STAND then only pour in 150cc.  It wont overflow, but it will be full.
« Reply #13 on: July 21, 2014, 05:41:35 PM »
Channellocks  cooldude
« Reply #14 on: July 21, 2014, 05:53:09 PM »
sounds good. Usually I do it off the bike now.
Ken Tarver
North Mississippi
« Reply #15 on: July 22, 2014, 06:33:22 AM »
Get one of these, also available at the discount auto part stores and probably Wally Mart. Makes life so easy. Color may vary, mine is white
http://www.harborfreight.com/gear-oil-and-fluid-pump-61746.html
Ken
Led
Wisconsin
« Reply #16 on: July 22, 2014, 11:53:41 AM »
I use a flex tube oil can, like the "old fashioned" types.
Just keep squirting oil in, with the bike on a level plane, until it finally overflows. Only a trickle of oil will come out (one squirt too much!!), but it will be completely full. Re-install the cap and clean everything up........DONE!!!!
http://www.harborfreight.com/20-oz-flexible-spout-oil-can-1113.html
« Reply #17 on: July 22, 2014, 11:57:16 AM »
How do you keep the bike perfectly vertical while filling?
specialdose
Jonesboro, Ga
« Reply #18 on: July 22, 2014, 11:59:35 AM »
    I am by no means a mechanic but can perform all my PM. I use a large general purpose shop syringe on the side stand....easy peasy.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #19 on: July 22, 2014, 12:09:04 PM »
I don't claim it was perfectly vertical, but I used jack stands under each side of the engine guards.
« Reply #20 on: July 22, 2014, 12:20:13 PM »
That's perfectly vertical enough for the job for sure.  If you don't do something like that, maybe even fill it on the side stand till it overflows, well it would be ever filled.  Good job!
I still think measure 150cc and do it on the side stand if you are set on doing it while its on the bike is easiest
« Last Edit: July 22, 2014, 12:45:16 PM by Chrisj CMA » Logged
Bone
« Reply #21 on: July 22, 2014, 12:40:39 PM »
That's a lot of oil.
« Reply #22 on: July 22, 2014, 12:45:55 PM »
sorry, I fixed it..........didnt see that extra 0
Ken Tarver
North Mississippi
« Reply #23 on: July 22, 2014, 03:12:30 PM »
homemade wood 2x4 wheel chock, park in it all time
Ken
MP
North Dakota
« Reply #24 on: July 22, 2014, 04:43:12 PM »
Chris.  I used to do the oil fill with the bike level.  Now, I do it on the side stand.  It is only a little more oil.  I thought maybe it would get in the pinion cup a little better.  I checked several times after filling, to be sure I wasn't throwing out oil with it a little overfull.  I wasn't.
On the sidecar IS, which is always level, I fill it till it starts coming out, then put a little more in.  Just a little.
Might be right, might be wrong.  But, it is my story, and I am sticking to it!  LOL
MP
"Ridin' with Cycho"
T-Bird
Cleveland, Tennessee
« Reply #25 on: July 22, 2014, 05:35:45 PM »
MP
MP
At Inzane this year, I heard some others talking about even putting the bike on a 2x4 and then over on the sidestand to fill it.  I would think that if there is too much it would just blow out the vent..but you would have plenty to get to the pinion cup. What do you think about this, would it (or could it) do harm if overfilled?
xman
Lincoln Park NJ, Valk Home Lackawaxen PA
« Reply #26 on: July 22, 2014, 07:09:06 PM »
To keep the bike level, on the ground. I mounted 2,  1 inch rings on the garage wall, about 4 ft apart. I put the bikes front wheel against the wall centered between the rings. I use 2 tie down straps from the handle bars to the rings. Put a little tension on the straps.
I fill with a thin tube attached to a funnel. I don't have bags but you do have to get it around the exhaust. Fill until it's running out the fill plug and it's good to go.
« Reply #27 on: July 22, 2014, 07:33:57 PM »
all that........................or just put in 150cc when its off the bike..................work smarter, not harder is my thing
Farther
Quimper Peninsula, WA
« Reply #28 on: July 22, 2014, 07:35:10 PM »
I do mine on the side stand, fill it until the lube runs out and, with three changes there has been no lose through the vent to date.
~Farther
MP
North Dakota
« Reply #29 on: July 23, 2014, 11:56:55 AM »
MP
MP
At some point it gets too full.  I do not know if it will do any damage, besides start to spit out oil.
MP
"Ridin' with Cycho"
Rio Wil
« Reply #30 on: July 23, 2014, 04:47:08 PM »
I am guessing there has been 10-15 K between changes.....at those intervals what has been the condition of the drive shaft/pinion cup splines. Did you lube up the splines with moly/grease or rely on the final drive fluid to do the lubrication through the 2 holes in the p-cup.......if relying on the final drive for lubrication, did that work well....???
john
tyler texas
« Reply #31 on: July 23, 2014, 09:14:55 PM »
 Shocked     ???     Roll Eyes    Undecided     coolsmiley    2funny 2funny 2funny
vrcc # 19002
« Reply #32 on: July 24, 2014, 05:52:38 AM »
Some of you guys crack me up.  A couple weeks ago we argued how if the pinch bolts on the front axle were off a ftlb or so you would die a flaming death.  Now we are arguing the fact that even though 150cc is the prescribed fill amount for the final drive... Im not sure if will hurt anything but my way insures there's extra in there, its just easier that way.
Maybe you're right and it doesn't matter.......what if too much oil causes your lube to foam up instead of misting inside the case?
Too much oil can cause this:
Foaming is a common problem with oil-lubricated components. It can be difficult to troubleshoot, and for this reason, accurate testing to determine the root cause of the foaming is essential.
Symptoms
 Foam is a collection of small bubbles of air that accumulate on or near the surface of the fluid. In severe cases, the foam can leak out of the machine through breathers, sight glasses and dipsticks. Foam is an efficient thermal insulator, so the temperature of the oil can become difficult to control. The presence of air bubbles in the fluid can lead to excessive oxidation, cavitation, the reduction of lubricating properties of the oil and hydraulic system failure
More is not always better, be careful out there
« Last Edit: July 24, 2014, 05:57:21 AM by Chrisj CMA » Logged
theredark
Derry, NH
« Reply #33 on: July 24, 2014, 12:15:57 PM »
You could also buy one of the little pumps that you screw onto an oil bottle to fill the lower drive of an outboard with.  They're pretty cheap,  in the marine section of Wal-Mart.
2000 Black/Red Interstate
« Reply #34 on: July 24, 2014, 01:18:25 PM »
Not sure who "You" is, but I just would rather do it when the final drive is off the bike.  Synthetic lube and do it every spline grease 10K or so interval is my norm.
Jopson
Egan SD
« Reply #35 on: July 24, 2014, 08:41:28 PM »
When I did mine I had it on the bench but to ensure the correct amount I got a cheap 50cc syringe from my local veterinary clinic for about $2. Worked really well and was cheap!
tpersson
« Reply #36 on: May 05, 2015, 11:50:01 AM »
Thanks for the post, it helped me with getting my oil changed on the final drive.  It was tough to get the top bolt off.  I took the side bag off, then lifted the bike on that side so get past the muffler.  I also used a small funnel and a clear hose (I had lying around), which worked well.  I did do what "Chrisj CMA" recommended, I measured 150ml.
My only struggle was getting my large torque wrench in position to tighten top bolt properly.  I just couldn't do it, so I did it by feel.
« Reply #37 on: May 05, 2015, 02:41:56 PM »
You don't really need a torque wrench for any of this. I haven't ever used one on my bike when servicing the final drive, only on the axle and the last four nuts in front of the final. That area isn't under pressure so just clean it all up and screw the plug in snug. Doesn't need anything else.
As I recall, the only thing I use a torque wrench on is both axles, the final's front four nuts, pinch bolts on the forks. Don't recall anything else.
pais
One more turn should do it!
Kent, Ohio
« Reply #38 on: May 05, 2015, 03:22:07 PM »
  Changed my final drive oil a couple weeks ago. Pulled drain plug, pulled vent plug and let it drain for half a day. Poured a small amount of fresh oil into vent opening and let that drain over night. Installed drain plug and filled through vent opening. Went well and vent cap/plug came out relatively easy and went back in, no problems.
   Rest assured I will do this service at tire change intervals! I love the "work smart not hard" theory.
westnek
« Reply #39 on: May 06, 2015, 04:50:55 PM »
  hi salty I  used a 1/2 in plastic hose and a copper elbow with about 3/4 in piece soldered on the elbow to make sure it goes in far enough ,,a funnel and away we go
