November 26, 2025, 03:30:10 AM *
Author Topic: More Than You Ever Wanted to Know:  (Read 835 times)
Rio Wil
« on: July 22, 2014, 10:19:00 PM »
about brake fluid....... crazy2 crazy2 crazy2 crazy2
http://www.lelandwest.com/brake-fluid-comparison-chart.cfm
« Reply #1 on: July 23, 2014, 07:57:35 AM »
I thought DOT4 meant a certain boiling temp. Each company has different boiling temps.
« Reply #2 on: July 23, 2014, 11:57:06 AM »
a minimum wet boiling temp must be met to be labeled a certain DOT.  for street use always use the highest wet boiling temp, this allows replacement interval to be extended past every 2 yrs.
road racers want the highest dry boiling point.
DOT 5.1 even though a higher WBT is designed for ABS systems and has a different viscosity than DOT 4. Some state braking performance can be reduced using 5.1 in a 4 or 3 system.
All DOT 3 and 4 fluids are synthetic and have been for decades don't believe the marketing hype.
DOT 5 is the silicone based fluid and is strictly a race track item and cannot be mixed with the other DOTs.
