November 26, 2025, 03:30:13 AM
Final Drive Maintenance Interval?
Topic: Final Drive Maintenance Interval? (Read 719 times)
theredark
Derry, NH
July 24, 2014, 12:19:59 PM »
Hey all,
Looking for a few opinions, sure there may be some here! I did a full final drive service 3K miles ago (pinion cup, new moly grease, 3 orings, the works). Now I've got the rear wheel off to change a tire. The splines look good and still well greased. Would you all recheck the full final drive or just relube the splines and put the wheel back on?
Brad
2000 Black/Red Interstate
Re: Final Drive Maintenance Interval?
July 24, 2014, 12:22:46 PM »
Since it was convenient presently, I'd be doing both.
My rides:
Bone
July 24, 2014, 12:33:38 PM »
I did a 5K service last year.
July 24, 2014, 12:55:33 PM »
With good servicing I've found I can go 10-12k but didn't the first couple times. I gradually increased the mileage and each time it was fine. So now unless something shows up, I'll run around 10-12k. So far, so good.
Used to coincide with replacing the rear tire. But now with the c/t in back I have to remember to service it regardless of whether I'm replacing it or not.
Last Edit: July 25, 2014, 07:21:50 PM by John Schmidt
Daniel Meyer
The State of confusion.
July 24, 2014, 01:02:39 PM »
Since it takes...like 10 minutes extra beyond a normal tire removal, I do it every time I have it off.
But...that said...at 3k miles I wouldn't sweat it. (as long as you tighten the 4 nuts that hold the final drive AFTER you torque the axle...every time)
CUAgain,
Daniel Meyer
=> InZane XXV
