November 19, 2025, 07:15:52 PM *
Author Topic: To soft "behind"  (Read 1834 times)
Relax
Power & elegance...just like the Valk
Oslo, Norway
« on: August 08, 2009, 01:55:24 PM »
I could like my Valk ( 2001, standard) some stiffer at the rear when loading up for longer rides.
I go 2 up and max load and I feel it "bumps" to the bottom of something every now and then,,
1. Can i destroy something when loading to much ?
2. Any idea where to buy air shock absorbers ...........or do anyone have an other idea?
« Reply #1 on: August 08, 2009, 02:29:27 PM »
You didn't give us much info.. What shocks are you using?? Where are they set??
Relax
Oslo, Norway
« Reply #2 on: August 08, 2009, 04:15:54 PM »
Ahh...sorry...
I have standard, original shock absorbers and they are set at 5 ( max load).The bike has about 50 000 miles on the clock and i have done mostly 2 up riding ( heavy load)
« Reply #3 on: August 08, 2009, 04:41:48 PM »
I and most here that have switched shocks have the Progressive 440 hd in a 12.5 length. I would almost suggest the same shocks except in the 13 in length. The stock shocks are equivalent to the 12.5 length so you would even get a little more travel. They will make quite a bit of difference in the ride and you shouldn't bottom out. Some have also gone to the works shocks that you may want to check into. The Progressive rears and fronts springs were one of the best mods I did made the world of difference in the ride.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #4 on: August 08, 2009, 04:47:21 PM »
+1...What Robert said  cooldude  I went Progressive 440's in the rear, set at 7 full turns out. Progressive springs in front. Very positive and noticable improvement.
john
tyler texas
« Reply #5 on: August 08, 2009, 05:24:53 PM »
before you spend the bread for progressive shocks ...    Shocked
try shocks off the interstate model valkyrie ...  coolsmiley
vrcc # 19002
tlanz
« Reply #6 on: August 08, 2009, 06:17:36 PM »
Most of my riding is two up also. I went with the Heavy Duty 13" Progressive 440's some 4 years and 30K miles ago. It was a VERY worthwhile investment. Recently, I noticed one of them was leaking fluid. Progressive rebuilt both of them for free; turn around time was about a week. they really do stand behind their lifetime warranty. Nice to know I'll never have to pay for another pair of shocks!
no affiliation, YMMV, yada yada yada...
« Last Edit: August 08, 2009, 06:19:20 PM by tlanz » Logged
« Reply #7 on: August 08, 2009, 06:47:53 PM »
Ditto! hoser
Relax
Oslo, Norway
« Reply #8 on: August 09, 2009, 12:37:38 AM »
Thanks guys........
Interstate versions are maybe the easy and good way out here,,,,
I'll check it out ,,,
thanks..
