February 09, 2026, 04:53:57 AM *
Author Topic: break away cruise control  (Read 1195 times)
blackvalkyrie
California
« on: July 26, 2014, 12:51:18 PM »
any one have a break away cruse control on their valk? I'm thinking of getting one, but not sure if it's worth the price?
thanks
BigBF
Text message at 602-332-4872
Phx AZ
« Reply #1 on: July 26, 2014, 01:11:20 PM »
thanks
Well worth it and love it.
You should expect struggle to adjust until you get it right.
blackvalkyrie
California
« Reply #2 on: July 26, 2014, 01:16:57 PM »
thanks man!
thanks
specialdose
Jonesboro, Ga
« Reply #3 on: July 26, 2014, 01:33:34 PM »
                   Pricey...but worth it. I have stock grips. Two adjustments 2 yrs ago works perfect. Looks like part of the bike.
                       Got mine on ebay.
BigBF
Phx AZ
« Reply #4 on: July 26, 2014, 08:55:48 PM »
You're welcome...
thanks man!
thanks
Kep
My "Mid-life Crisis "
Indiana
« Reply #5 on: July 26, 2014, 09:16:26 PM »
Love mine...love it love it !
olddog1946
Moses Lake, Wa
« Reply #6 on: July 26, 2014, 09:31:53 PM »
I picked one up off of a CL ad, brand new for a 100 bucks, took all of 20 minutes to install and adjust. I love having it dis-engage when I hit the brakes...that's one reason I never liked throttle locks. In an emergency the last thing you are thinking about is releasing a locked throttle.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #7 on: July 27, 2014, 08:59:18 AM »
Have one on my bike.  Wouldn't ever be without one now.   cooldude
Tailgate Tommy
Fort Collins, Colorado
« Reply #8 on: July 27, 2014, 10:01:45 AM »
Just installed one this year and it's great. I have ISO grips and the wide levers. A bit of a fiddly PITA to get adjusted but when you do no issues.
Marinakorp
King of Prussia, PA
« Reply #9 on: July 28, 2014, 05:51:37 AM »
I have one on my Standard.. wit hte ISO grips.
Agree that once it is adjusted, it works great.... just getting it adjusted correctly was a pain for me...
Love it!
I would rather be judged by 12 than carried by 6
DarkSideR
Pueblo, Colorado
« Reply #10 on: July 28, 2014, 06:13:09 AM »
I have the Break Away Throttle Lock, and am really happy with it.
I do however want to give you a heads up. I have stock grips on my bike. The chrome ring on the inside of the grip rotated independently from the rest of the grip. The Throttle Lock grabs on the that chrome ring, my speed would not hold because the while the lock held tight the chrome ring the grip itself would rotate freely. I thought at first that the Throttle Lock didn't work, but when I discovered this and fixed it found the Throttle Lock works perfectly.
Hope this helps if you too run into your Throttle Lock not working with OEM Grips.
ps - How did I fix it? I pulled the chrome ring away from the grip, super glued it, and pushed it back together.
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
HickoryNCInterstate
« Reply #11 on: July 28, 2014, 11:35:02 AM »
I have the ISO grips, works great on flat surfaces, even small hills just disengage is my finding. Maybe mine is not adjusted correctly??
Marinakorp
King of Prussia, PA
« Reply #12 on: July 28, 2014, 12:38:53 PM »
Yes... not adjusted correctly.
I can hit a fairly solid BUMP in the road at speed... still stays locked... until I hit hte brakes or hit the off switch / button...
BigBF
Phx AZ
« Reply #13 on: July 28, 2014, 02:04:21 PM »
Yup you need to adjust little more... I know it's pita...
blackvalkyrie
California
« Reply #14 on: July 30, 2014, 02:55:19 PM »
thanks for the heads up!  I do have oem grips on my standard..  when you say chrome ring on the inside of  the grip  how did you pull it away from the grip? do they pull off the handlebar or are they glued  on?
thanks cooldude
blackvalkyrie
California
« Reply #15 on: July 30, 2014, 02:57:09 PM »
Thanks to  all for the input cooldude
blackvalkyrie
California
« Reply #16 on: July 30, 2014, 02:59:03 PM »
I also had the old style and it's super dangerous when in an emergency and trying  to disengage tickedoff
