November 26, 2025, 03:29:50 AM
front shocks (forks) problems
Topic: front shocks (forks) problems (Read 655 times)
fubar606
eastern washington
July 26, 2014, 04:49:14 PM »
2000 IS just got back from a 770 mile run and the front end sounds like bed springs squeaking. I bet I can be heard coming down the road for a 1/4 mile there are no visible spots rubbing there are know seals leaking can't find anything . would it be bad to put a little grease on the tubes or will it just collect dirt and make it worse ?? OR is it a sign of something worse in side the tubes
life is sexually transmitted and always fatal
Re: front shocks (forks) problems
July 26, 2014, 05:07:14 PM »
DO NOT put lube on the exposed fork tubes. Clean them up and dry them off. Are your brake pads releasing properly? Is the fairing tight to the mount? Excess play in clutch or brake lever? Not being able to hear your noise how bout wheel bearings? How many miles on her? Are the rotors tight? Others most likely will chime In also. Good luck with yer problemo. RIDE SAFE.
fubar606
eastern washington
July 26, 2014, 05:22:32 PM »
the squeak seem only when the forks compress and release
=> InZane XXV
