November 26, 2025, 03:47:00 AM *
Author Topic: Best Brake Pads??  (Read 930 times)
GPz1100
Texas
« on: July 28, 2014, 03:55:01 PM »
my 'new to me' Valkyrie needs new brake pads.
what type of pads work best on this bike? kevlar, organic kevlar, semi-metallic...etc.
any brand better than another?
also, i'm going to measure the rotors to make sure they are good also. if not they will be replaced too.
Dorkman
San Carlos, CA
« Reply #1 on: July 28, 2014, 04:13:18 PM »
Do a search on brake pads and you will get many opinions.  Generally, many recommendations for OEM pads on OEM rotors.  Soft organic pads are also easy on the rotors.  There are some cheaper soft pads out there, and you will find recommendations.  The danger is that hard pads cause wear on the rotors.
TJ
Lake Placid , Fl.
« Reply #2 on: July 28, 2014, 04:22:56 PM »
O.E.M.
BigBF
Text message at 602-332-4872
Phx AZ
« Reply #3 on: July 28, 2014, 04:38:31 PM »
Recommend honda brake pads...
EBC lot of owner hate it due to noise....
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #4 on: July 28, 2014, 06:01:47 PM »
O.E.M.
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
GPz1100
Texas
« Reply #5 on: July 28, 2014, 07:04:40 PM »
ok. sounds good. i'll go oem pads.
i was looking up the part numbers and found there are two numbers for each set.
maybe two different compounds? here's a link for the rear pads...
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500C+A/REAR+BRAKE+CALIPER/parts.html
did i look up the wrong model?
BigBF
Phx AZ
« Reply #6 on: July 28, 2014, 07:43:42 PM »
Bottom is new number top is old number
Like this
(06435-MZ0-006) (replaces 06435-MZ0-760)
GPz1100
Texas
« Reply #7 on: July 28, 2014, 08:00:12 PM »
ahh. makes sense now. thanks for that
« Reply #8 on: July 29, 2014, 07:27:53 AM »
Vesrah  which makes most of the OEM pads, lower price and can get them as a thicker pad for longer wear.
http://www.vesrah.com/
search my posts for brake pad info
« Reply #9 on: July 29, 2014, 07:02:11 PM »
+1
Hay  Cool
« Reply #10 on: July 29, 2014, 07:09:47 PM »
Yes Honda makes a fine brake pad.  cooldude
GPz1100
Texas
« Reply #11 on: July 29, 2014, 07:14:32 PM »
ok. honda pads ordered.
