November 26, 2025, 03:50:27 AM *
Author Topic: rear shocks for 1998 F6  (Read 1897 times)
bsg
naples
« on: July 29, 2014, 11:48:35 AM »
Hey everyone,
 just bought a 1998 F6 and while going though the bike believe it needs new rear shocks . The manual said place on sidestand and remove one shock at a time and the other will hold but it's not even close to holding, Is there any good option other than $ 1000 stock replacement from Honda. Need front and rear tires also and want good quality but it's adding up fast.
Thanks for any advice and will try to post some pic.
Scott
« Reply #1 on: July 29, 2014, 12:07:25 PM »
keep an eye out for used Interstate shocks... unworn-out ones are OK...
Progressive 440 shocks... I think they are 444's now...
Works Performance shocks...
« Reply #2 on: July 29, 2014, 12:27:01 PM »
The manual said place on sidestand and remove one shock at a time and the other will hold...
Is this in the owner's manual?  I can't find it in the service manual.
Marinakorp
King of Prussia, PA
« Reply #3 on: July 29, 2014, 01:03:26 PM »
Progressive only lists the 412 and the 416 for the Valkyrie...
Where re the 444?
I would rather be judged by 12 than carried by 6
bsg
naples
« Reply #4 on: July 29, 2014, 01:05:56 PM »
It's a Clymer must also be a aftermarket manual, Thanks was looking also at the 430 progressive
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #5 on: July 29, 2014, 01:07:05 PM »
Nothing wrong with the Progressive 412's  cooldude  I've have a set (with the HD springs) and they have kept my 270 lb azz and my Valk happy, for many years  Wink
Black Dog
Don't you know...
« Reply #6 on: July 29, 2014, 01:23:25 PM »
If those are stock shocks, and they are on the lowest setting, I believe that one shock will not hold the bike at the top.
That's not a good test of anything!
Even old as they are, they are still lots better than aftermarket shocks.
Oem is the only way to go, and Interstate shocks are the best for stiff riding, if that's what you're looking for.
« Reply #7 on: July 29, 2014, 01:30:07 PM »
Your OEM Interstate shocks were stiffer than your HD 440s? Wow...
« Reply #8 on: July 29, 2014, 02:12:22 PM »
Shock replacement. Raise the bike on a lift til the rear wheel is off the ground. Change one shock at a time. If you invest in a lift and adapter, it'll save you money in the long run. You can change the wheels which will save on mounting/balancing. .... Post where you live and somebody close might be able to help.
8Track
Adelaide, South Australia
« Reply #9 on: July 29, 2014, 03:25:29 PM »
If the rear shocks are not leaking, just replace the springs like I did. It only cost about $80.
Here is my old thread with the details:
http://www.valkyrieforum.com/bbs/index.php/topic,45903.msg447981.html#msg447981
Paxton
So Cal
« Reply #10 on: July 29, 2014, 05:30:28 PM »
I/S shock is good but for your application, so are the Tourer and/or Standard OME Shocks. Undecided
Notwithstanding, you might just need to change the rubber bushings on the ones you have. Wink
Need new tires? Go Darkside. Roll Eyes cooldude
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
bsg
naples
« Reply #11 on: July 30, 2014, 02:54:39 PM »
thanks for all of the input, went with progressive 440 "13 invested about 650.00. no lift so will take it and have the tires put on with the new shocks. metzler? tires o.k for a bike that will only get maybe 500 miles a year around town. I am way down south on the west coast of florida, hot in the summer and full of old tourists in the winter
« Reply #12 on: July 30, 2014, 03:45:31 PM »
You should visit the FL VRCC Board and seek help..... there's all kinds of old bastards down there riding around on Valks that will be glad to help you out.   2funny
olddog1946
Moses Lake, Wa
« Reply #13 on: July 30, 2014, 05:44:15 PM »
Now Now, don't be mean .....there are old bastards in every part of the country that will help out if they can.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Paxton
So Cal
« Reply #14 on: July 30, 2014, 07:56:33 PM »
"... full of old tourists in the winter."
 ??? What? Yes, they are old... But they are NOT darn tourists. tickedoff   Ask the VRCC experts! laugh Evil 2funny
J. Paxton Gomez
So Cal... 91205
Anthony
Belgium
« Reply #15 on: July 31, 2014, 02:32:35 AM »
a good test is to measure initial sag:
measure vertically between bottom bolt of shock and a point on the fender rail, without any load on it.
measure vertically again, with the usual load on the bike, in upright position : rider (+ passenger) (+ luggage) + ...
the difference between these 2 measurements is called the 'initial sag'
set the pre load on the shocks as high untill you come to a point that the initial sag = 1 inch.
if your initial sag is higher then 1", even in the highest preload setting on the shocks, the shocks are not (or no longer) good for your typical load.
Anthony
westnek
« Reply #16 on: July 31, 2014, 09:14:02 AM »
the adapter is it the wood type and will it allow you to remove one wheel at a time with out  toppling bike off -I have a bottle 'black jack ' foot pedal with two cross members on it  same one as I saw   with a wooden adapter, ive raised the bike BUT  havnt  removed wheels  [yet ]-
« Reply #17 on: July 31, 2014, 09:40:46 AM »
The best way to incur drive train damage is to:
You don't need a lift to change shocks.  Many have done it on the side stand, its just a little harder.
If you are going to have the dealer R/R the wheels for new tires, first YOU learn the process especially for the rear.  Then ask a lot of questions about how the mechanic is going to do it, what grease, the 4 bolts etc.  So you know if its worth the risk of having them do it or not.  If you don't know whats supposed to be done, you will never know it they did it right or not.  Well, until you have a drive train failure prematurely.
bsg
naples
« Reply #18 on: July 31, 2014, 01:44:48 PM »
I am taking it to the Honda dealer for that purpose  of hopefully doing it right , have never had a shaft drive bike, but the shocks are 444's and will soon get some pic. if not too difficult.
Thanks again for the help and I am one of those old bastards as well.
8Track
« Reply #19 on: July 31, 2014, 11:30:15 PM »
A Honda dealer servicing the rear end end using correct procedure and bolting it up correctly? Not very likely!!
Read Shoptalk section here and know what should and shouldn't be done. You can then ensure the dealer does things correctly.
